Здравейте.
Да нов съм, но мисля че тук е подходящо място да попитам.
От Event Viewer -> Windows Logs -> Security
виждам следните логове:
Audit Access / 4672 (Event ID) / Special Logon (Task Category)
Event Properties:
Special privileges assigned to new logon.
Subject:
Security ID: SYSTEM
Account Name: SYSTEM
Account Domain: NT AUTHORITY
Logon ID: 0x3e7
Privileges: SeAssignPrimaryTokenPrivilege
SeTcbPrivilege
SeSecurityPrivilege
SeTakeOwnershipPrivilege
SeLoadDriverPrivilege
SeBackupPrivilege
SeRestorePrivilege
SeDebugPrivilege
SeAuditPrivilege
SeSystemEnvironmentPrivilege
SeImpersonatePrivilege
Audit Access / 4624 (Event ID) / Logon (Task Category)
Event Properties:
An account was successfully logged on.
Subject:
Security ID: SYSTEM
Account Name: ME-PC$
Account Domain: WORKGROUP
Logon ID: 0x3e7
Logon Type: 5
New Logon:
Security ID: SYSTEM
Logon ID: 0x3e7
Logon GUID: {00000000-0000-0000-0000-000000000000}
Process Information:
Process ID: 0x258
Process Name: C:\Windows\System32\services.exe
Network Information:
Workstation Name:
Source Network Address: -
Source Port: -
Detailed Authentication Information:
Logon Process: Advapi
Authentication Package: Negotiate
Transited Services: -
Package Name (NTLM only): -
Key Length: 0
This event is generated when a logon session is created. It is generated on the computer that was accessed.
The subject fields indicate the account on the local system which requested the logon. This is most commonly a service such as the Server service, or a local process such as Winlogon.exe or Services.exe.
The logon type field indicates the kind of logon that occurred. The most common types are 2 (interactive) and 3 (network).
The New Logon fields indicate the account for whom the new logon was created, i.e. the account that was logged on.
The network fields indicate where a remote logon request originated. Workstation name is not always available and may be left blank in some cases.
The authentication information fields provide detailed information about this specific logon request.
- Logon GUID is a unique identifier that can be used to correlate this event with a KDC event.
- Transited services indicate which intermediate services have participated in this logon request.
- Package name indicates which sub-protocol was used among the NTLM protocols.
- Key length indicates the length of the generated session key. This will be 0 if no session key was requested.
Това което ме притеснява е Logon Process: Advapi
След бърза проверка в Google разбрах, че това е Remote Trojan, а аз имам Големи съмнения, че съм хакнат.
Не.Знаех си че това ще се попита.Най забавното е че емайлите са несъществуващи, да бяха гмайл или нещо друго нямаше да ми пука но бяха в абв.
След като пуснах тема в един друг форум... запаметените емаили освен тези 2та непознати и моя, се появиха този на сестра ми и на баща ми.. а и 2та са ползвали пс-то само веднъж.. след това броузера ми се прецака смених го и от тогава никакви емайли не се запаметяват.
всякакъв възможен, в момента съм с Нод32 .. днес ставам и клавиатурата ми (отделна, с лаптоп съм) е откачила натискам едно то се натиска друго, някои бутони не работят, като натисна някоя буква съвсем друга команда подава.
Всъщност не, само бутоните по реда q w e r и т.н. са откачили.
Сканирай с Malwarebytes Anti-Malware. Ако тепърва инсталираш програмата, в края инсталацията ще има отметка за автоматична актуализация, не я премахвай. В противен случай обнови дефинициите й ръчно. Ако вече имаш програмата, провери дали имаш последната версия и ако нямаш, премахни твоята и инсталирай най-новата, като в края на инсталацията остави отметката за актуализация на дефинициите.
Инструкции за сканиране:
- стартирай програмата;
- ако са открити заплахи, кликни бутон OK и после Show Results (Покажи резултатите);
Ако е нужен рестарт, се съгласи и рестартирай веднага. След рестарта стартирай отново програмата, иди на подпорозиорец Logs (Дневници), маркирай последния дневник, кликни бутон Open (Отвори) и му копирай съдържанието тук. Ако не е бил нужен рестарт, трябва да се появи текстов файл - копирай му съдържанието тук.
изпълних всички стъпки , malware, OTL , combofix и все още имам съмнение че съм хакнат и то не от кой да е.
Темата бях я пуснал в един друг популярен форум, няма да му казвам името само ще кажа че темата му е същата.
Главно искам да разбера с какво си имам работа.
От личен опит ти казвам не прави свободни съчинения особено със ComboFix.Следвай инструкциите точно и ясно няма да ти се обърне гръб.И аз веднъж взех нещата във свои ръце (ComboFix) след рестарт на машината не ми разпознаваше клавиатурата...........и се наложи преинсталация загубено време и работа за около 2м. отидоха на вятъра..............ComboFix във ръцете на не опитен потребител(като мене) вреди!!!!!!!!!И по разни други форуми съм засичал коментари "пусни един ComboFix и си готов"........да ама не..............
