Lamerando Публикувано Юни 20, 2012 Report Share Публикувано Юни 20, 2012 Здравейте , четах много за моя проблем направих всичко ,но не помогна нищо....И той е ,че нямам звук в браузъра ,а иначе с winamp и kmplayer нямам проблеми....Стигнах до заключението ,че имам вируси етото лога от SuperAntiSpyware и от МаlwarebytesИзтрих всичко ,което ми засякоха програмите ,но звука не се върна.... Деинсталирах флаш плеъра и го инсталирах на ново след почистването и пак няма звук в мозила.... Някакви идеи mbam-log-2012-06-20 (16-37-55).txt SUPERAntiSpyware Scan Loghttp://www.superantispyware.com Generated 06/20/2012 at 04:53 PM Application Version : 5.1.1002 Core Rules Database Version : 8763Trace Rules Database Version: 6575 Scan type : Complete ScanTotal Scan Time : 01:05:22 Operating System InformationWindows XP Professional 32-bit, Service Pack 3 (Build 5.01.2600)Administrator Memory items scanned : 347Memory threats detected : 0Registry items scanned : 31122Registry threats detected : 10File items scanned : 13509File threats detected : 2 PUP.StartNow Toolbar HKCR\CLSID\{6E13D095-45C3-4271-9475-F3B48227DD9F} HKCR\CLSID\{6E13D095-45C3-4271-9475-F3B48227DD9F}#ProgID HKCR\CLSID\{6E13D095-45C3-4271-9475-F3B48227DD9F}#VersionIndependentProgID HKCR\CLSID\{6E13D095-45C3-4271-9475-F3B48227DD9F}#TypeLib HKCR\CLSID\{6E13D095-45C3-4271-9475-F3B48227DD9F}\InprocServer32 HKCR\CLSID\{6E13D095-45C3-4271-9475-F3B48227DD9F}\InprocServer32#ThreadingModel HKCR\CLSID\{6E13D095-45C3-4271-9475-F3B48227DD9F}\Programmable HKLM\Software\Classes\CLSID\{6E13D095-45C3-4271-9475-F3B48227DD9F} HKLM\Software\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{6E13D095-45C3-4271-9475-F3B48227DD9F} HKU\S-1-5-21-1614895754-507921405-839522115-1003\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{6E13D095-45C3-4271-9475-F3B48227DD9F} Trojan.SimitraD-Loader D:\SYSTEM VOLUME INFORMATION\_RESTORE{38E04974-7556-4E16-9278-7F5B7FF701FB}\RP3\A0006796.EXE Trojan.Agent/Gen-FraudPack E:\SYSTEM VOLUME INFORMATION\_RESTORE{38E04974-7556-4E16-9278-7F5B7FF701FB}\RP3\A0006797.EXE Сега установих ,че като пусна CS или някоя друга игра компютъра ми се растартира и след включване ми изкарва това съобщение ....Когато пусна пък KMplayer ми изкарва това съобщение изтрих го и пак го инсталирах и пак няма ефект.... Цитирай Link to comment Сподели другаде More sharing options...
Lamerando Публикувано Юни 20, 2012 Author Report Share Публикувано Юни 20, 2012 Странните неща продължават .Пускам си музика от Winamp няма проблем пускам филм пак през Winamp няма звук... Пускам филм през KMPLAYER има звук , пускам филм през GOMPLAYER също няма звук :( Когато се изключва или включва компютъра и вместо началната мелодия , се чува само част от нея и после нещо като пукане и спира...При грешките ,когато дава windowsa е същата работа ,чува се само част от онзи гаден звук и пак едно пукане на колоните.... Сканирах няколко пъти с SuperAntiSpyware и логовете са едни и същи всеки път трия тези гадини и като пусна пак сканиране те пак са си там...Да отбележа само ,че при всяко завършено сканирани и след като изтрия гадините давам на програмата да си направи рестартирването ......Интересен е факта ,че всеки път броят им е различен...Ето и последното сканиране преди секунди ;(New Text Document.txt Цитирай Link to comment Сподели другаде More sharing options...
panevdd Публикувано Юни 20, 2012 Report Share Публикувано Юни 20, 2012 Какви кодеци си инсталирал? Цитирай Link to comment Сподели другаде More sharing options...
Lamerando Публикувано Юни 20, 2012 Author Report Share Публикувано Юни 20, 2012 K-Lite Mega Codec Pack 8.7.0 Цитирай Link to comment Сподели другаде More sharing options...
panevdd Публикувано Юни 20, 2012 Report Share Публикувано Юни 20, 2012 Деинсталирай го, рестартирай системата и виж дали още имаш проблеми със звука. Цитирай Link to comment Сподели другаде More sharing options...
Lamerando Публикувано Юни 20, 2012 Author Report Share Публикувано Юни 20, 2012 Подобрение няма , и това съм го направил същата работа ,си е...Продължавам ,да си мисля ,че е от тези гадинки ,които не мога да изтрия...Ще чакам някой от по-запознатите в тази област да помагат ,да се справим с проблема... Цитирай Link to comment Сподели другаде More sharing options...
Night_Raven Публикувано Юни 22, 2012 Report Share Публикувано Юни 22, 2012 Виждам инсталирани приложения за "оптимизация" като TuneUp Utilities и Registry Repair Wizard. Не знам какво си правил с тях, но ще те посъветвам да ги разкараш и никога да не прибягваш отново до тях.Колкото до проблема, в случай, че не е причинен от въпросните "оптимизиращи" приложения, бих те посъветвал да си актуализираш всички драйвери като за начало. Може да е от помощ и ако дадеш списък на инсталираните приложения. Цитирай Link to comment Сподели другаде More sharing options...
