Проблем с отваряне на Facebook
  • 3 weeks later...
  • Отговори 180
Стартирай отново OTL. В празното поле "Custom Scans/Fixes" (в долната част на програмата) постави следния текст (маркирай го, натисни Ctrl+C и после в полето на OTL натисни Ctrl+V):
:Processes
killallprocesses
:OTL
O4 - HKLM..\Run: []  File not found
O4 - HKLM..\Run: [avast5]  File not found
O4 - HKLM..\Run: [s6000Mnt]  File not found
O4 - HKLM..\Run: [tray_ico]  File not found
O4 - HKLM..\Run: [tray_ico3]  File not found
O4 - HKLM..\Run: [tray_ico4]  File not found
O4 - HKU\S-1-5-21-1576462213-2801439982-1300003180-1006..\Run: [ooVoo.exe]  File not found
O4 - Startup: C:\Documents and Settings\All Users\Start Menu\Programs\Startup\McAfee Security Scan Plus.lnk =  File not found
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: EnableLUA = 0
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: EnableSecureUIAPaths = 0
O31 - SafeBoot: AlternateShell - services32.exe
[2011.08.09 20:35:17 | 000,000,000 | -H-D | C] -- C:\WINDOWS\update.3
[2011.07.27 02:36:33 | 000,000,000 | -H-D | C] -- C:\WINDOWS\update.tray-12-0-lnk
[2011.07.26 16:02:53 | 000,000,000 | -H-D | C] -- C:\WINDOWS\update.2
[2011.07.26 16:01:46 | 000,000,000 | ---D | C] -- C:\WINDOWS\ufa
[2011.07.26 16:01:46 | 000,000,000 | ---D | C] -- C:\WINDOWS\phoenix
[2011.07.26 15:58:45 | 000,000,000 | -H-D | C] -- C:\WINDOWS\update.5.0
[2011.07.26 15:42:05 | 000,000,000 | ---D | C] -- C:\WINDOWS\av_ico
[2011.07.26 15:40:42 | 000,000,000 | -H-D | C] -- C:\WINDOWS\update.1
[2011.07.26 15:40:37 | 000,000,000 | -H-D | C] -- C:\WINDOWS\update.tray-9-0-lnk
[2011.07.26 15:40:37 | 000,000,000 | -H-D | C] -- C:\WINDOWS\update.tray-7-0-lnk
[2011.08.09 20:35:17 | 000,000,202 | ---- | M] () -- C:\WINDOWS\info1
[2011.07.26 16:01:45 | 005,589,370 | ---- | M] () -- C:\WINDOWS\phoenix.rar
[2011.07.26 16:01:45 | 000,246,272 | ---- | M] () -- C:\WINDOWS\unrar.exe
[2011.07.26 16:01:45 | 000,182,617 | ---- | M] () -- C:\WINDOWS\ufa.rar
[2011.07.26 16:01:43 | 001,075,284 | ---- | M] () -- C:\WINDOWS\rpcminer.rar
[2011.07.26 16:00:02 | 000,904,792 | ---- | M] () -- C:\WINDOWS\geoiplist.rar
[2011.07.26 15:58:53 | 000,000,000 | ---- | M] () -- C:\WINDOWS\loader2.exe_ok
[2011.07.17 03:24:20 | 004,636,907 | ---- | M] () -- C:\WINDOWS\geoiplist
:Files
C:\WINDOWS\services32.exe
C:\WINDOWS\*.tmp
C:\WINDOWS\System32\*.tmp
:Commands
[emptytemp]
[resethosts]
[reboot]
Копирай текста точно както е в полето. Внимавай да не изтървеш началното двуеточие и всяка команда да е на отделен ред, както е в полето.
Кликни бутон Run Fix. Потвърди с OK на съобщението, че е нужен рестарт на системата.
След рестарта ще се появи текстов дневник/лог. Същият файл се намира в C:\_OTL\MovedFiles. Моля, прикачи го към следващия си коментар.
След това стартирай отново OTL, създай пресни дневници (както бях описал по-рано) и ги прикачи отново. Можеш да архивираш всичките файлове в един архив, а можеш и да ги прикачиш поотделно.
Свали RogueKiller на работния плот. Стартирай файла, натисни клавиш 3 и след това Enter. Накрая трябва да ти се отвори текстов файл-дневник. Копирай съдържанието му тук или го прикачи към коментара си (файлът се намира на работния плот).
RogueKiller V5.3.3 [08/18/2011] by Tigzy
contact at http://www.sur-la-toile.com
mail: tigzyRK<at>gmail<dot>com
Feedback: http://www.sur-la-toile.com/discussion-193725-1-BRogueKillerD-Remontees.html
Operating System: Windows XP (5.1.2600 Service Pack 3) 32 bits version
Started in : Normal mode
User: acer [Admin rights]
Mode: HOSTSFix -- Date : 08/20/2011 14:23:47
Bad processes: 0
HOSTS File:
127.0.0.1 localhost
127.0.0.1 vkontakte.ru
127.0.0.1 www.vkontakte.ru
127.0.0.1 login.vk.com
127.0.0.1 vk.com
127.0.0.1 www.vk.com
127.0.0.1 odnoklassniki.ru
127.0.0.1 www.odnoklassniki.ru
127.0.0.1 facebook.com
127.0.0.1 www.facebook.com
127.0.0.1 af-za.facebook.com
127.0.0.1 az-az.facebook.com
127.0.0.1 id-id.facebook.com
127.0.0.1 ms-my.facebook.com
127.0.0.1 bs-ba.facebook.com
127.0.0.1 ca-es.facebook.com
127.0.0.1 cs-cz.facebook.com
127.0.0.1 cy-gb.facebook.com
127.0.0.1 da-dk.facebook.com
127.0.0.1 de-de.facebook.com
Resetted HOSTS:
127.0.0.1 localhost
Finished : << RKreport[1].txt >>
RKreport[1].txt
Ще е добре да проверим за остатъци.
Сканирай с Malwarebytes' Anti-Malware. Ако вече имаш програмата, провери дали имаш последната версия и ако нямаш, премахни твоята и инсталирай най-новата. Ако тепърва инсталираш програмата, след инсталацията тя ще предложи да се актуализира автоматично, съгласи се. В противен случай обнови дефинициите й ръчно.
- стартирай програмата;
Ако е нужен рестарт, се съгласи и рестартирай веднага.
Стартирай отново OTL и кликни бутон CleanUp. Това ще премахне инструмента и принадлежащите му фалове и папки.
Можеш да изтриеш и RogueKiller и създадения от него дневник.
