Проблем със System Restore.
ozic
Хммм пробвай с това:
INF File Association Fix (Restore the default assocation for INF files)
Изтегли го, разархивирай го, стартирай *.reg файла и избери YES за да влязат промените в сила...
Още за System Restore:
System Restore Tab Missing
Check your settings here: For Pro: Start/Run/gpedit.msc. Computer
Configuration, Administrative Templates, System, System Restore.
Re-Enabling System Restore (WinXP Pro)
If you previously disabled system restore through the Group Policy Editor,
the option to start it again does not show in the System Properties. You can
re-enable it again by:
1. Run the Group Policy Editor (gpedit.msc)
2. Go to Computer Configuration / Administrative Templates / System / System
Restore
3. Set Turn off System Restore and Turn off Configuration to Disable
4. Right click on My Computer
5. Select Manage
6. Go to Services and Applications / Services
7. Scroll down to System Restore Service
8. Set it for Automatic
9. Click on the Start button to start the service
10. Close down this window
11. Go back to the Group Policy Editor and configure both to Not configured
12. Now when you right click on My Computer, there should be a tab for
System Restore and you can configure how much space will be used.
This issue can occur if there are corrupted restore points or some
related system files are missing. To troubleshoot this issue, let's go
through the following steps:
Part I. Disable and then re-enable the System Restore feature:
1. Click the Start menu -> Run. Type "sysdm.cpl" (Without quotation
marks) in the Open field. Click OK.
2. Click the "System Restore" tab.
3. Click to check the "Turn off System Restore on all drives" box, and
click OK.
4. Restart the computer.
5. Click the Start menu -> Run. Type "sysdm.cpl" (Without quotation
6. On the "System Restore" tab, remove the check mark from the "Turn
off System Restore on all drives" box, and click OK.
7. Restart the computer again.
8. Check whether you can use the System Restore function.
За *.INF файлове бих ти препоръчал и TuneUp Utilities 2007 (не 2008) като краен вариант.Слагаш отметка пред
INF FILES CANNOT BE INSTALLED и избираш Next =>
http://img113.imageshack.us/img113/41/tuneyc1.jpg
(Night_Raven знам, че не я харесва особено :booo: )
Успех!
Има възможност страницата System Restore да изчезне от аплета System, ако е конфигурирана такава групова политика. За целта може да провериш следното:
1. Отвори Start --> Run... ---> "gpedit.msc".
2. Избери Computer Configuration--> Administrative Templates--> System --> System Restore.
3. Кликни два пъти върху Turn off System Restore и се увери, че е е селектиран радиобутона Not Configured. Ако не е, избери го, потвърди с Apply и затвори прозореца с OK.
4. Затвори Group Policy Editor.
P.S.: Услугата на System Restore в този случай няма връзка. Ако не е стартирана просто няма да се наблюдава системата, но страницата System Restore ще фигурира в System. :)
Има много добра причина да не я харесвам. Всичко, което може да се настрои с TuneUp, може да се направи от самия Windows, TweakUI или .reg файлчета, които се намират на сайта на Kelly Theriot . Ако случайно се пръкне някоя настройка, която я няма из споменатите от мен места, то ползата и удобството й са под въпрос. Просто МРАЗЯ програми, които експлоатират безплатно достъпни неща, за да се правят на уникални/полезни.
Подготвям специален материал за TuneUp 2008 по въпроса. Нещо като АНТИръководство.
За жалост не става по описаните начини !
TuneUp Utilities е 2008,файла го разархивирах и му дадох Yes,след това рестартирах,по мнението на l.kanelov-селектирано е Not Configured.
Аз не я ползвам тази функция,но Your Uninstaller! 2008,не иска да деинсталира,ако е спряна.
INF File Association Fix (Restore the default assocation for INF files) и TuneUp 2007 бяха предложени само заради поправката на *.INF файловете...Пробва ли сега да дадеш INSTALL върху sr.inf ?
За версия 2008 на TuneUp не открих функцията от снимката, която съм ти дал по-нагоре...
Както казва Night_Raven нямаш нужда от Your Uninstaller! (но предполагам ползваш версия 2008, защото се съмнявам и версия 2006 да не иска да деинсталира при спрян System Restore)... ;)
Пробвах и дадох инстал,но ми иска нещо допълнително/ако не се лъжа файл от i386/. Дали обаче трябва да сложа диска на Уиндоуса/ХР SP 2 Pro-имам го/ ?
За Your Uninstaller съм чел все добри неща и наистина при 2006 не пречеше че е спрян System Restore.
Разбира се, че трябва да го поставиш. То това е идеята - преинсталация на System Restore.
То добри думи има и за TuneUp, System Mechanic и други програми, но това не ги прави добри. Те 90% от потребителите повтарят като папагали това, което прочетат някъде. Нали знаеш - когато една лъжа се повтори достатъчно брой пъти, се превръща в истина. Маркетинговите отдели са сила.
Имам следният проблем-изключих преди два дена функцията System Restore,но не мога сега да я включа наново !
В My computer---Properties го няма . Бихте ли ми помогнали ?
Сканирай под Safe Mode за вируси и шпионски софтуер, току-виж станало чудото.
намерих и това предложение:
http://windowsitpro.com/article/articleid/...-not-start.html
в случай че нямаш вирус/адуер, който да си е направил майтап със "прозореца"
Успех! :thumbsup:
