Проблем с намиране на мрежата при рестартиране
bokanegra
  • Отговори 72
Дай по една снимка от System Information - страниците Conflicts/Sharing и IRQs.
I/O Port 0x00000000-0x00000CF7 PCI bus
I/O Port 0x00000000-0x00000CF7 Direct memory access controller
I/O Port 0x000003C0-0x000003DF VIA CPU to AGP2.0/AGP3.0 Controller
I/O Port 0x000003C0-0x000003DF RADEON 9200 SERIES
IRQ 21 VIA Rev 5 or later USB Universal Host Controller
IRQ 21 VIA USB Enhanced Host Controller
Memory Address 0xD8000000-0xE7FFFFFF VIA CPU to AGP2.0/AGP3.0 Controller
Memory Address 0xD8000000-0xE7FFFFFF RADEON 9200 SERIES
I/O Port 0x00009000-0x00009FFF VIA CPU to AGP2.0/AGP3.0 Controller
I/O Port 0x00009000-0x00009FFF RADEON 9200 SERIES
IRQ 9 Microsoft ACPI-Compliant System
IRQ 9 SCSI/RAID Host Controller
IRQ 16 RADEON 9200 SERIES
IRQ 16 Realtek RTL8139/810X Family PCI Fast Ethernet NIC
Memory Address 0xA0000-0xBFFFF PCI bus
Memory Address 0xA0000-0xBFFFF VIA CPU to AGP2.0/AGP3.0 Controller
Memory Address 0xA0000-0xBFFFF RADEON 9200 SERIES
I/O Port 0x000003B0-0x000003BB VIA CPU to AGP2.0/AGP3.0 Controller
I/O Port 0x000003B0-0x000003BB RADEON 9200 SERIES
IRQ 0 System timer OK
IRQ 1 Standard 101/102-Key or Microsoft Natural PS/2 Keyboard OK
IRQ 3 Communications Port (COM2) OK
IRQ 4 Communications Port (COM1) OK
IRQ 5 Multimedia Audio Controller OK
IRQ 6 Standard floppy disk controller OK
IRQ 8 System CMOS/real time clock OK
IRQ 9 Microsoft ACPI-Compliant System OK
IRQ 9 SCSI/RAID Host Controller OK
IRQ 10 MPU-401 Compatible MIDI Device OK
IRQ 12 PS/2 Compatible Mouse OK
IRQ 13 Numeric data processor OK
IRQ 14 Primary IDE Channel OK
IRQ 15 Secondary IDE Channel OK
IRQ 16 RADEON 9200 SERIES OK
IRQ 16 Realtek RTL8139/810X Family PCI Fast Ethernet NIC OK
IRQ 18 ESS 1969 PCI AudioDrive (WDM) OK
IRQ 21 VIA Rev 5 or later USB Universal Host Controller OK
IRQ 21 VIA USB Enhanced Host Controller OK
Опитай да настроиш slot-а, на който ти е LAN картата, да използва IRQ 3, 4, 6 или 21.
Ами пробвах всички,обаче нещо не става-не иска да запамети настройката,защото после като влязя в IRQ настройките си стои все една и съща-тази първоначалната-16/май беше/ и не иска да се променя??
Сещам се за още две възможности:
1. Да промениш настройките с помощта на Device Manager - изключваш опцията Use automatic settings и задаваш нов IRQ.
http://img409.imageshack.us/img409/1452/dmgrix0.png
2. Да деинсталираш LAN картата (цъкаш с десен бутон върху името и в Device Manager -> Uninstall) и при следващия рестарт да промениш IRQ-то и от настройките в BIOS.
Има и друг вариант: в BIOS-а изключи всички неща, които не ползваш - COM портове, LPT порт, GamePort и др. Това ще освободи IRQ-та и може да повлияе положително.
Добре де,възможно ли е това??? И това пробвам-и пак не става.....Преинстал. на лана;пак промяна на IRQ-и пак така.....как така не я намира тази мрежа бе м...ма му с...ра.,какво толкова му пречи??? :blink: :blink: :blink:
Aми мисля ,че нямам чак толкова излишни работи....така като гледаш по-горе ти как мислиш?
В допълнение. Не отговори на доста въпроси, зададени досега.
Хубаво е да споделиш какъв Windows използваш. Също така какво си добавял към него. Не каза дали си инсталирал AutoPatcher.
Има вариант някое хардуерно устройство, инсталирано при теб да бърка работата. Затова послушай panevdd за снимката. (Start>Settings>Control Panel>System>Device Manager и кликваш на Network Adapters).
как се прави такава снимка?
