Проблем с инсталацията на Xara Web Style
Тръгвам аз да инсталирам Xara Web Style 4 и ми казва че искам IE 5,обаче аз го имам ие 5 :) ъпдейтвам до IE 6 + Sp1 и почвам да инсталирам и пак ми изписва че искам IE 5 O_O какво да правя?
тук
Редактиран от mireto
Погледна ли линка, който ти е даден на съобщението. Там пише точно как да се оправиш:
Internet Explorer
Webstyle 4 requires the Microsoft Data Access Components version 2.1 or later.
A minimal install of IE 5 or IE 6 does not include this but it can be installed by adding the "Dynamic HTML Data Binding" component listed in the IE setup program.
This can be located as follows:
• Run "Add/Remove Programs" in Control Panel.
• Select "Microsoft Internet Explorer 5/6 and Internet Tools".
• Click "Add/Remove".
• Select "Add a component" and click OK.
• Check the box next to "Dynamic HTML Data Binding" and click Next.
• After the installation has completed click Finish and your machine will be rebooted.
After the reboot, run the Webstyle 4 installer again and it should complete successfully.
If this procedure does not work then you can either upgrade to a more recent version of Internet Explorer or you can install a version of the Microsoft Data Access Components directly.
For IE 6:
http://www.microsoft.com/windows/ie/default.asp
Пиши какво е станало.
