shade_darkness Публикувано Февруари 28, 2011 Report Share Публикувано Февруари 28, 2011 Здравейте на всички! Norton Internet Security 2011 съм на инсталиран WinXP SP3, наскоро си преинсталирах ОС, преди което си и форматирах дяла c: 2 пъти, инсталирах NIS 2011, и оттогава постоянно получавам това в историята на стената, не използвам рутер: Category: Firewall - ActivitiesDate & Time,Risk,Activity,Status,Recommended Action,Category28.2.2011 г. 23:30,Info,"Unused port blocking has blocked communications. Inbound TCP connection from 194.187.135.66, local service Port (18558) .",Detected,No Action Required,Firewall - Activities28.2.2011 г. 23:30,Info,"Unused port blocking has blocked communications. Inbound TCP connection from 194.187.135.66, local service Port (18558) .",Detected,No Action Required,Firewall - Activities28.2.2011 г. 23:29,Info,"Unused port blocking has blocked communications. Inbound TCP connection from 84.252.7.223, local service Port (36580) .",Detected,No Action Required,Firewall - Activities28.2.2011 г. 23:29,Info,"Unused port blocking has blocked communications. Inbound TCP connection from 212.233.203.39, local service Port (41754) .",Detected,No Action Required,Firewall - Activities28.2.2011 г. 23:29,Info,"Unused port blocking has blocked communications. Inbound TCP connection from 212.233.203.39, local service Port (41754) .",Detected,No Action Required,Firewall - Activities28.2.2011 г. 23:29,Info,"Unused port blocking has blocked communications. Inbound TCP connection from 194.187.135.66, local service Port (18558) .",Detected,No Action Required,Firewall - Activities28.2.2011 г. 23:29,Info,"Unused port blocking has blocked communications. Inbound TCP connection from 79.132.19.250, local service Port (41754) .",Detected,No Action Required,Firewall - Activities28.2.2011 г. 23:28,Info,"Unused port blocking has blocked communications. Inbound TCP connection from 91.196.224.211, local service Port (41754) .",Detected,No Action Required,Firewall - Activities28.2.2011 г. 23:28,Info,"Unused port blocking has blocked communications. Inbound TCP connection from 194.187.135.66, local service Port (18558) .",Detected,No Action Required,Firewall - Activities28.2.2011 г. 23:28,Info,"Unused port blocking has blocked communications. Inbound TCP connection from 212.233.203.39, local service Port (41754) .",Detected,No Action Required,Firewall - Activities28.2.2011 г. 23:28,Info,"Unused port blocking has blocked communications. Inbound TCP connection from 194.187.135.66, local service Port (18558) .",Detected,No Action Required,Firewall - Activities28.2.2011 г. 23:27,Info,"Unused port blocking has blocked communications. Inbound TCP connection from 79.132.19.250, local service Port (41754) .",Detected,No Action Required,Firewall - ActivitiesТова е част от исторята на защитната стена продължава постоянно и е около 20 страници вече и не спира. Използвам софтуер от торенти и други подобни, но направих 3 пълни сканирания с антивирусната, със оналайн скенер на Bitdefender и оналайн скенера на Symantec - показва че системата е чиста. Консолтирах се с Symantec и казаха че няма за какво да се притеснявам, четох из мрежата че това може да е сканиране за отворени портове или от т.нар "зомби компютри" (не разбирам много от компютри) за пролуки в защитната стена или незнам точно какво, защитната ми стена е с включен HIPS имам строги определени правила за всичко и съм блокирал почти всичко за досъп in/out и преди няколко часа някакво ip от малайзия или нз как беше се опита да се свърже с моя компютът (Inbound Connection) през lsass.exe процеса на Windows блокирах го разбира се. Въпросът ми е трябва ли да се притеснявам защитана стена ще се подадели скоро ако продължава това, възможно ли да от някой програма или крак да предава от моя pc навън (малко вероятно но не го изключвам), да сменя NIS със касперски, четох че защитната им стена е по-добра или да форматирам c: и да преинсталирам системата?Помогнете. Цитирай Link to comment Сподели другаде More sharing options...
Night_Raven Публикувано Февруари 28, 2011 Report Share Публикувано Февруари 28, 2011 Не мисля, че има място за притеснения. Сканирането на портове е нормално явление, така че няма нищо необичайно, че има такива обекти в дневника на защитната стена. Цитирай Link to comment Сподели другаде More sharing options...
Гост tnn Публикувано Март 1, 2011 Report Share Публикувано Март 1, 2011 Не мисля, че има място за притеснения. Сканирането на портове е нормално явление, така че няма нищо необичайно, че има такива обекти в дневника на защитната стена.Няма как да съм съгласен - ако ще е инсталирал Norton Internet Security 2011 от някакви торент-тракери, той с много глупости може и още да те занимава. Не ми се коментира.С легалния NIS 2011 не се случват подобни неща. Нищо, че аз не го ползвам...Противопоказно е защитни програми да се теглят от такива съмнителни места.Това поне се пише из всички форуми...Обаче те трябва да се посещават и да се чете... Цитирай Link to comment Сподели другаде More sharing options...
mihnev_sz Публикувано Март 2, 2011 Report Share Публикувано Март 2, 2011 С легалния NIS 2011 не се случват подобни неща. Не блокира входящ трафик ли?Нали не си мислиш че всички всички потребители са зад фирмен рутер като тебе,при определени настройки на рутера може и да не му се налага да блокира! Цитирай Link to comment Сподели другаде More sharing options...
Гост tnn Публикувано Март 2, 2011 Report Share Публикувано Март 2, 2011 Вярно. Наивно си е да се теглят защитни програми примерно от The Pirate Bay и да се очаква пълноценно, продължително и безплатно те да си работят.Вероятността WinXP SP3 на съфорумеца пак да е инфектирана е много висока. Цитирай Link to comment Сподели другаде More sharing options...
paro Публикувано Март 2, 2011 Report Share Публикувано Март 2, 2011 Спокойно, няма място за абсолютно никакви притеснения. Аз на твое място бих се притеснил, ако нямаше нищо в лога на стената. Преди време бях със стена на Касперски и имах доста такива съобщения в лог-файла на стената. Така, че ако всичко друго е наред и имаш нормален интернет трафик, няма от какво да се притесняваш! Цитирай Link to comment Сподели другаде More sharing options...
