Търся firewall програма
Field	Value
Computer
Computer Type	ACPI Multiprocessor PC
Operating System	Microsoft Windows XP Professional
OS Service Pack	Service Pack 3
Internet Explorer	6.0.2900.5512
DirectX	4.09.00.0904 (DirectX 9.0c)
Computer Name	DIMITAR
User Name	MuTk0o0
Logon Domain	DIMITAR
Date / Time	2009-06-28 / 01:12
Motherboard
CPU Type	Intel Pentium 4 530J, 3000 MHz (15 x 200)
Motherboard Name	FUJITSU SIEMENS D1826-G
Motherboard Chipset	Intel Grantsdale i915P
System Memory	2048 MB  (PC3200 DDR SDRAM)
DIMM1: Hynix HYMD264 646D8J-D43	512 MB PC3200 DDR SDRAM  (3.0-3-3-8 @ 200 MHz)  (2.5-3-3-7 @ 166 MHz)  (2.0-2-2-6 @ 133 MHz)
DIMM2: Hynix HYMD264 646D8J-D43	512 MB PC3200 DDR SDRAM  (3.0-3-3-8 @ 200 MHz)  (2.5-3-3-7 @ 166 MHz)  (2.0-2-2-6 @ 133 MHz)
DIMM3: Hynix HYMD264 646D8J-D43	512 MB PC3200 DDR SDRAM  (3.0-3-3-8 @ 200 MHz)  (2.5-3-3-7 @ 166 MHz)  (2.0-2-2-6 @ 133 MHz)
DIMM4: Hynix HYMD264 646D8J-D43	512 MB PC3200 DDR SDRAM  (3.0-3-3-8 @ 200 MHz)  (2.5-3-3-7 @ 166 MHz)  (2.0-2-2-6 @ 133 MHz)
BIOS Type	Phoenix (04/07/05)
Communication Port	Communications Port (COM1)
Display
Video Adapter	NVIDIA GeForce 7800 GT  (256 MB)
3D Accelerator	nVIDIA GeForce 7800 GT
Monitor	Samsung SyncMaster 177N/710N/MagicSyncMaster CX701N/CX711N  [17" LCD]  (HMDL307124)
Multimedia
Audio Adapter	Creative Audigy 2 ZS (SB0350) Sound Card
Audio Adapter	Realtek ALC880(D) @ Intel 82801FB ICH6 - High Definition Audio Controller [b-1]
Storage
IDE Controller	Intel® 82801FB Ultra ATA Storage Controllers - 2652
IDE Controller	Intel® 82801FB/FBM Ultra ATA Storage Controllers - 266F
Storage Controller	AX2HHZZ2 IDE Controller
Floppy Drive	Floppy disk drive
Disk Drive	Generic STORAGE DEVICE USB Device
Ами за предпочитане е да е безплатна,но ако има по-добра платена,съм съгласен и на този вариант.
Първо разгледай темите Защитни стени - въпроси, мнения, предимства, недостатъци, Дискусия: Как защитавате компютъра си?, Firewall+Hips и Ползвате ли защитна стена и ако да, коя?.
Избери си няколко стени, след което потърси нагледна информация за тях в раздела с изображения в Google. Така ще имаш представа как се управлява съответния продукт, без да се налага да го инсталираш.
Моето предложение: Sygate Personal Firewall Free. Не се поддържа отдавна - Symantec закупиха Sygate и вградиха стената в Symantec Endpoint Protection 11.0, без да я видоизменят, което според мен е показател за качеството на програмата. Имай предвид, обаче, че това е "чист" firewall и няма да те предпази от вируси и malware, действащи локално на твоя компютър, без да изискват връзка с мрежата.
В момента най-добрата защитна стена е Comodo Firewall Pro, която вече се предлага с анти-вирус, но при желание анти-вирусът може да не се инсталира! Малко по-труден за настройки може да ти бъде заради малко объркващия интерфейс на програмата, но ако се спреш на Комодо аз или Tanganika ще ти помогнем да я настроиш и опознаеш! Другата също така много-добра защитна стена е Online Armour. Тя пък е с доста орязани функции, но е по-опростена, и мисля че е по-подходяща за теб!И двете стени са безплатни, така че ти решаваш! Това са двете най-добри защитни стени за момента и всички други, поне според тестове на независими лаборатории са под класата на Комодо и ОА!
Download Comodo IS
Download Online-Armour
Download Comodo IS
Бих искал да те попитам,наистина ли outpost pro,отстъпва на горните две чуствително?Така ми звучи''под класата''.Аз се спрях на Оutpost pro,защото е и по-лека и с по-интуитивен интерфейс,което ми се струва също важно.Поне спрямо comodo.
Недей се вързвай на "крайните" изказвания на този или онзи потребител!
Същото е както това, "санчо" да ти каже, че "от линукса по-добро нема!"
Outpost-a е чудесна програма, отличаваща се с лесен и интуитивен вид.
Работата с нея е опростена, менютата определено НЕ са объркващи.
Води се user-friendly, нещо което е вярно и за Online Armor, но не и за Comodo!
Попитах от чисто любопитство.По никакъв начин не бих я заменил,ако ще и да отстъпва с 10-15 % на горните две.Сменям нещо,едва когато се убедя сам,че трябва.Благодаря за съвета все пак :giggle:
Разбира се, че не отстъпва значително. Просто има хора, за които това е ежедневният репертоар - "програма Х цепи мрака и всички й дишат прахта". Comodo Internet Security, Online Armor и Outpost Firewall са трите най-добри програми за защита, ако говорим за anti-leak защита. Ако премахнем това, стените стават общо взето посредствени.
Отделно не бих казал, че Online Armor е много орязана. Повече от достатъчна е за един обикновен потребител.
dImIt01, като цяло бих ги препоръчал, ако HIPS механизми са нужни на системата. Конкретно от тези трите бих посъветвал да започнеш с Outpost Firewall Free, защото според мен е най-оптималният вариант от другите. Comodo Internet Security е (поне според мен) много объркваща, нищо че изглежда лъскава, а Online Armor пък не е от най-леките стени. Outpost Firewall Free има удобен интерфейс като Online Armor, но не е толкова тежка (отново по мое мнение).
Алтернативи са PC Tools Firewall Plus и Webroot Desktop Firewall. И двете са безплатни и съдържат също HIPS механизми. Тези механизми са на теория по-слаби от тези на по-горните, но си остават достатъчно добри. По принцип PC Tools нямат кой знае колко добри продукти, но стената им е прилична и лесна за работа. Стемата на Webroot е на практика Privatefirewall на Privacyware, но с друго лого и пусната безплатно.
Има и други предложения, но те изискват повече познания при работата със стени, така че не са удачни.
Outpost е по-тежка от Comodo, може да е с малко, но отстъпва!
-справя се по-зле при вътрешните атаки може да е с малко, но отстъпва!
- не дава толкова големи привилигии за настройка, както е при Comodo може да е с малко, но отстъпва!
Може би има и още показатели, по които Outpost отстъпва на Comodo, и като ги събереш процентите, макар и незначителни, стават значителни...особено за хора, които са по-взискателни на тема:"сигурност и защита"!
И тук не става lвъпрос за крайности, много моля - без осъждение!
Не съм рекламен агент на Comodo, нито пък работя в компанията разработваща защитния софтуер!
Доволен съм от нея, чета постове по другите форуми и следя тестовете, които правят независимите лаборатории...но най-вече на праден план е личното убеждение от перфектната работа на Comodo! Дайте да не се осъждаме, защото не всеки, който е доволен и препоръчва даден продукт, е негов маниакален фен!
Outpost отстъпва макар и с малко? Дори и да е така, за един обикновен потребител това не е от значение. Според теб за един човек има ли значение дали колата му има максимална скорост от рода на 190 или 200 км/ч? Има ли практическа разлика за човек, който ще ползва автомобила за градско шофиране?
Като събереш процентите в случая не се получава особено много. Особено при положение, че има и доста други фактори, които трябва да се вземат предвид. А това е от значение повече за онези потребители, които си мислят, че като си инсталират теоритично най-добрата програма проблемите им приключват и стават недосегаеми. Един истински опитен потребител не се впечатлява от някакви незначителни проценти по тестове и ползва това, което му е удобно и му допада.
Защитната стена не прави защитата. Потребителят я прави. Същото важи и за компютърната сигурност като цяло.
Ако някой харесва Comodo Internet Security и му е удобна за работа, нека я ползва. Няма нищо лошо в това. Но да се стига до отричане на всичко останало е присъщо основно за мислещите се за разбирачи, но реално неопитни потребители.
Я дай някой тестове на "независими лаборатории" да видим.
Благодаря Ви много за изчерпателните отговори.Изчетох темите от panevdd,за което ти благодаря.Ще си сложа Outpost Firewall Free,както Night_Raven ме посъветва.Ако имам въпроси се надявам да разчитам на Вас.
Night_Raven,имам един въпрос.Има ли някакво значение дали ще е безплатната или платената версия на програмата.Всмисъл,аз прочетох тук ,но не знам дали от тези фунцкии на платената версия,стената ще стане по-надеждна.Та, те трябват ли ми?
Това са разликите според официалния сайт:
http://i39.tinypic.com/a2u936.jpg
Разбрах за отговорите.Въпросът ми беше дали това ще повлияе на програмата,дали ще е по-надеждна и по-сигурна или е все едно и също със или без тях.
