Грешка при опит да изпратя мейл към outlook или друга поща
Всеки път при опит да изпратя или препратя съобщение от някакъв mail към outlook или към друг mail, получавам следното съобщение:
Undelivered Mail Returned to Sender
This is the mail system at host mx2.mail.bg.
I'm sorry to have to inform you that your message could not
be delivered to one or more recipients. It's attached below.
For further assistance, please send mail to webmaster@mail.bg
If you do so, please include this problem report. You can
delete your own text from the attached returned message.
Това е мейл системата на хост mx2.mail.bg.
За съжаление вашето съобщение не можа да бъде доставено до
един или повече получатели. Приложено е по-долу.
За допълнителна помощ, пишете на webmaster@mail.bg, като включите
това съобщение за грешка. Може да изтриете вашия текст и
прикачени файлове, преди да го изпратите.
<****@outlook.com>: host mx1.hotmail.com[65.55.92.****] said: 550 SC-001
(SNT004-MC2F37) Unfortunately, messages from 193.201.172.**** weren't sent.
Please contact your Internet service provider since part of their network
is on our block list. You can also refer your provider to
http://mail.live.com/mail/troubleshooting.aspx#errors. (in reply to MAIL
FROM command)
Reporting-MTA: dns; mx2.mail.bg
X-Postfix-Queue-ID: E083960001F8
X-Postfix-Sender: rfc822; ****@mail.bg
Arrival-Date: Thu, 2 Jun 2016 21:18:21 +0300 (EEST)
Final-Recipient: rfc822; ****@outlook.com
Original-Recipient: rfc822;****@outlook.com
Action: failed
Status: 5.0.0
Remote-MTA: dns; mx1.hotmail.com
Diagnostic-Code: smtp; 550 SC-001 (SNT004-MC2F37) Unfortunately, messages from
193.201.172.****weren't sent. Please contact your Internet service provider
since part of their network is on our block list. You can also refer your
provider to http://mail.live.com/mail/troubleshooting.aspx#errors.
Return-Path: <****@mail.bg>
Received: from mail.bg (unknown [10.0.0.17])
    by mx2.mail.bg (Postfix) with ESMTPA id E083960001F8
    for <****@outlook.com>; Thu, 2 Jun 2016 21:18:21 +0300 (EEST)
DKIM-Signature: v=1; a=rsa-sha256; c=simple/simple; d=mail.bg; s=default;
    t=1464891501; bh=Vs0YbvaQHjv3XNTe7CIUOlTN+eZtrJSouEHaBZdugiA=;
    h=Message-ID:Date:Subject:From:To:MIME-Version:Content-Type;
    b=JRl9y8pUc/9UcUsaFRUY8h/SAcErWDSuQru7Zc+SoXuwetan612VJnstD0pGoeaW7
     J/BO1dvxgYYkoepHXBz3SnZG/ujzTGSzsN+yfqL/7r9Sva+44Lzd8issb7oER7teRR
     bDT6R4a+Yh4q69crnj1OHcST/EMJFFt2gxr3ikl4=
Message-ID: <8509a940490a581f6330b1f88db237fe.mailbg@mail.bg>
Date: Thu, 2 Jun 2016 18:18:21 -0000
Subject: =?utf-8?B?RldEOiAyINC/0YDQtdC/0YDQsNGC0LXQvdC4INC/0LjRgdC80LA=?=
To: ****@outlook.com
User-Agent: Mail.BG Webmail
MIME-Version: 1.0
Content-Type: multipart/mixed;boundary="----=_20160602181821_70266"
X-Priority: 3 (Normal)
Importance: Normal
X-Composed: 2016-06-02T18:18:21+00:00
X-Originating-IP: [****.****.****.****]
На какво се дължи?
193.201.172.118 (IP на mail.bg) е блокирано от Майкрософт, защото от него е изпращано SPAM.
Единствено те(mail.bg) като собственици на IP-то(мрежата) мога да го делистнат в някои от 'порталите" на Майкрософт:
https://postmaster.live.com/snds/
В повечето случаи след заявка и няколко имейла с индийците на Майкрософт, до седмица, се делиства адреса.
Предлагам ти да пробваш следното: създай си профил в Google. Пробвай да препратиш писмата си от mail.bg към новосъздадената поща в Google. После препращаш от Google към Outlook. След това ако повече не ти трябва профил в Google можеш да го изтриеш. Малка заигравка е, но може да се получи.
Писах им, никъв отговор. Несериозна работа!!! Почнах да се ядосвам......
Питаш ли ме като ми трябваше да се свърза със системния им администратор.. беше нужно да се свързвам с познати, от които да взема някакви телефони за връзка с офиса им....
Тъй като и двата сървъра, от които искаш да прехвърлиш писмата имат IMAP поддръжка, можеш да ползваш следния инструмент:
http://imapsync.lamiral.info/
Нужен ти е само един Линукс и да инсталираш инструментчето на него. След което пишеш една команда с информация за сървърите и данните за достъп и чакаш всичко да се прехвърли.
* Ако срещат затруднение с инструмента ми пиши ЛС, за да обясня по-подробно.
Аз вече ги прехвърлих към gmail след това към Outlook.
Иначе благодаря. За напред ако пак стане така ще го имам предвид.
