Мисля, че е редно да премахваш антивирусни само с инструментите, определени за целта от производителите им, ESET не са автори на AVG. Опитай с посочените инструменти, защото явно AVG все още присъства на системата ти.
  • Отговори 76
Направих го и ето какво изписа.(error: e0010013)
2010-10-14 18:43:53,890 DEBUG Avg8Uninstall\Directories key failed to open (error: e0010013)
2010-10-14 18:43:53,890 DEBUG Reading HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion:ProgramFilesDir (x86) value failed (error: e001003d)
2010-10-14 18:43:53,906 INFO Command line: "C:\AVGTemp\avg2011remover_en\avgremoverx.exe"
2010-10-14 18:43:54,125 WARN AvgDir param empty.
2010-10-14 18:43:54,125 WARN AvgAdminDir param empty.
2010-10-14 18:43:54,125 WARN AvgDataDir param empty.
2010-10-14 18:43:58,296 INFO AvgRemover runs in attempt number 1
2010-10-14 18:43:58,296 INFO ***** Msi data *****
2010-10-14 18:43:58,312 DEBUG Extracting msizap.exe from .cab archive
2010-10-14 18:43:58,312 INFO ***** Exchange plugins data *****
2010-10-14 18:43:58,328 INFO Exchange not instaled on this machine
2010-10-14 18:43:58,328 INFO ***** Services *****
2010-10-14 18:43:58,328 INFO Processing service avg8emc, it can take several minutes...
2010-10-14 18:43:58,328 INFO Service avg8emc is not installed
2010-10-14 18:43:58,328 INFO Processing service avgfws8, it can take several minutes...
2010-10-14 18:43:58,328 INFO Processing service avg8wd, it can take several minutes...
2010-10-14 18:43:58,328 INFO Processing service AvgWFPx, it can take several minutes...
2010-10-14 18:43:58,328 INFO Processing service AvgWFPa, it can take several minutes...
2010-10-14 18:43:58,328 INFO Processing service avg9wd, it can take several minutes...
2010-10-14 18:43:58,328 INFO Processing service AvgMfx86, it can take several minutes...
2010-10-14 18:43:58,328 INFO Processing service AvgMfx64, it can take several minutes...
2010-10-14 18:43:58,328 INFO Processing service AvgLdx86, it can take several minutes...
2010-10-14 18:43:58,328 INFO Processing service AvgLdx64, it can take several minutes...
2010-10-14 18:43:58,328 INFO Processing service AvgTdiX, it can take several minutes...
2010-10-14 18:43:58,328 INFO Processing service AvgTdiA, it can take several minutes...
2010-10-14 18:43:58,328 INFO Processing service AvgRkx86, it can take several minutes...
2010-10-14 18:43:58,328 INFO Processing service AvgRkx64, it can take several minutes...
2010-10-14 18:43:58,328 INFO Processing service avg9emc, it can take several minutes...
2010-10-14 18:43:58,328 INFO Processing service avgfws9, it can take several minutes...
2010-10-14 18:43:58,328 INFO Processing service avgfws, it can take several minutes...
2010-10-14 18:43:58,328 INFO Processing service AVGIDSAgent, it can take several minutes...
2010-10-14 18:43:58,328 INFO Processing service AVGIDSShimxpx, it can take several minutes...
2010-10-14 18:43:58,328 INFO Processing service AVGIDSFilterxpx, it can take several minutes...
2010-10-14 18:43:58,328 INFO Processing service AVGIDSDriverxpx, it can take several minutes...
2010-10-14 18:43:58,328 INFO Processing service AVGIDSShimvtx, it can take several minutes...
2010-10-14 18:43:58,328 INFO Processing service AVGIDSFiltervtx, it can take several minutes...
2010-10-14 18:43:58,328 INFO Processing service AVGIDSDrivervtx, it can take several minutes...
2010-10-14 18:43:58,328 INFO Processing service AVGIDSFiltervta, it can take several minutes...
2010-10-14 18:43:58,328 INFO Processing service AVGIDSDrivervta, it can take several minutes...
2010-10-14 18:43:58,406 INFO Service AVGIDSDrivervta is not installed
2010-10-14 18:43:58,406 INFO Service AVGIDSFiltervta is not installed
2010-10-14 18:43:58,406 INFO Service AVGIDSDrivervtx is not installed
2010-10-14 18:43:58,406 INFO Service AVGIDSFiltervtx is not installed
2010-10-14 18:43:58,406 INFO Service AVGIDSShimvtx is not installed
2010-10-14 18:43:58,406 INFO Service AVGIDSDriverxpx is not installed
2010-10-14 18:43:58,406 INFO Service AVGIDSFilterxpx is not installed
2010-10-14 18:43:58,406 INFO Service AVGIDSShimxpx is not installed
2010-10-14 18:43:58,406 INFO Service AVGIDSAgent is not installed
2010-10-14 18:43:58,406 INFO Service avgfws is not installed
2010-10-14 18:43:58,406 INFO Service avgfws9 is not installed
2010-10-14 18:43:58,406 INFO Service avg9emc is not installed
2010-10-14 18:43:58,406 INFO Service AvgRkx64 is not installed
2010-10-14 18:43:58,406 INFO Service AvgRkx86 is not installed
2010-10-14 18:43:58,406 INFO Service AvgTdiA is not installed
2010-10-14 18:43:58,406 INFO Service AvgTdiX is not installed
2010-10-14 18:43:58,406 INFO Service AvgLdx64 is not installed
2010-10-14 18:43:58,406 INFO Service AvgLdx86 is not installed
2010-10-14 18:43:58,406 INFO Service AvgMfx64 is not installed
2010-10-14 18:43:58,406 INFO Service AvgMfx86 is not installed
2010-10-14 18:43:58,406 INFO Service avg9wd is not installed
2010-10-14 18:43:58,406 INFO Service AvgWFPa is not installed
2010-10-14 18:43:58,406 INFO Service AvgWFPx is not installed
2010-10-14 18:43:58,421 INFO Service avg8wd is not installed
2010-10-14 18:43:58,421 INFO Service avgfws8 is not installed
2010-10-14 18:43:58,421 DEBUG Service avg8emc RegCleanup
2010-10-14 18:43:58,421 INFO Processing service AVGIDSShimw7x, it can take several minutes...
2010-10-14 18:43:58,421 INFO Processing service AVGIDSFilterw7x, it can take several minutes...
2010-10-14 18:43:58,421 INFO Processing service AVGIDSDriverw7x, it can take several minutes...
2010-10-14 18:43:58,421 INFO Processing service AVGIDSFilterw7a, it can take several minutes...
2010-10-14 18:43:58,421 INFO Processing service AVGIDSDriverw7a, it can take several minutes...
2010-10-14 18:43:58,421 INFO Processing service AVGIDSErHrxpx, it can take several minutes...
2010-10-14 18:43:58,421 INFO Processing service AVGIDSErHrvtx, it can take several minutes...
2010-10-14 18:43:58,421 INFO Processing service AVGIDSErHrvta, it can take several minutes...
2010-10-14 18:43:58,421 INFO Processing service AVGIDSErHrw7x, it can take several minutes...
2010-10-14 18:43:58,421 INFO Processing service AVGIDSErHrw7a, it can take several minutes...
2010-10-14 18:43:58,421 INFO Processing service avgwd, it can take several minutes...
2010-10-14 18:43:58,421 INFO Processing service AvgAdminServer, it can take several minutes...
2010-10-14 18:43:58,468 DEBUG Registry keys for service avg8emc are not present
2010-10-14 18:43:58,515 INFO Service AvgAdminServer is not installed
2010-10-14 18:43:58,515 INFO Service avgwd is not installed
2010-10-14 18:43:58,515 INFO Service AVGIDSErHrw7a is not installed
2010-10-14 18:43:58,515 INFO Service AVGIDSErHrw7x is not installed
2010-10-14 18:43:58,515 INFO Service AVGIDSErHrvta is not installed
2010-10-14 18:43:58,515 INFO Service AVGIDSErHrvtx is not installed
2010-10-14 18:43:58,515 INFO Service AVGIDSErHrxpx is not installed
2010-10-14 18:43:58,515 INFO Service AVGIDSDriverw7a is not installed
2010-10-14 18:43:58,515 INFO Service AVGIDSFilterw7a is not installed
2010-10-14 18:43:58,515 INFO Service AVGIDSDriverw7x is not installed
2010-10-14 18:43:58,515 INFO Service AVGIDSFilterw7x is not installed
2010-10-14 18:43:58,515 INFO Service AVGIDSShimw7x is not installed
2010-10-14 18:43:58,515 DEBUG Service avgfws8 RegCleanup
2010-10-14 18:43:58,515 DEBUG Service avg8wd RegCleanup
2010-10-14 18:43:58,515 DEBUG Service AvgWFPx RegCleanup
2010-10-14 18:43:58,515 DEBUG Service AvgWFPa RegCleanup
2010-10-14 18:43:58,515 DEBUG Service avg9wd RegCleanup
2010-10-14 18:43:58,515 DEBUG Service AvgMfx86 RegCleanup
2010-10-14 18:43:58,515 DEBUG Service AvgMfx64 RegCleanup
2010-10-14 18:43:58,515 DEBUG Service AvgLdx86 RegCleanup
2010-10-14 18:43:58,515 DEBUG Service AvgLdx64 RegCleanup
2010-10-14 18:43:58,515 DEBUG Service AvgTdiX RegCleanup
2010-10-14 18:43:58,515 DEBUG Service AvgTdiA RegCleanup
2010-10-14 18:43:58,515 DEBUG Service AvgRkx86 RegCleanup
2010-10-14 18:43:58,515 DEBUG Service AvgRkx64 RegCleanup
2010-10-14 18:43:58,515 DEBUG Service avg9emc RegCleanup
2010-10-14 18:43:58,515 DEBUG Service avgfws9 RegCleanup
2010-10-14 18:43:58,515 DEBUG Service avgfws RegCleanup
2010-10-14 18:43:58,515 DEBUG Service AVGIDSAgent RegCleanup
2010-10-14 18:43:58,515 DEBUG Service AVGIDSShimxpx RegCleanup
2010-10-14 18:43:58,515 DEBUG Service AVGIDSFilterxpx RegCleanup
2010-10-14 18:43:58,515 DEBUG Service AVGIDSDriverxpx RegCleanup
2010-10-14 18:43:58,515 DEBUG Service AVGIDSShimvtx RegCleanup
2010-10-14 18:43:58,515 DEBUG Service AVGIDSFiltervtx RegCleanup
2010-10-14 18:43:58,515 DEBUG Service AVGIDSDrivervtx RegCleanup
2010-10-14 18:43:58,515 DEBUG Service AVGIDSFiltervta RegCleanup
2010-10-14 18:43:58,515 DEBUG Service AVGIDSDrivervta RegCleanup
2010-10-14 18:43:58,546 DEBUG Registry keys for service avgfws8 are not present
2010-10-14 18:43:58,546 DEBUG Registry keys for service avg8wd are not present
2010-10-14 18:43:58,546 DEBUG Registry keys for service AvgWFPx are not present
2010-10-14 18:43:58,546 DEBUG Registry keys for service AvgWFPa are not present
2010-10-14 18:43:58,546 DEBUG Registry keys for service avg9wd are not present
2010-10-14 18:43:58,546 DEBUG Registry keys for service AvgMfx86 are not present
2010-10-14 18:43:58,546 DEBUG Registry keys for service AvgMfx64 are not present
2010-10-14 18:43:58,546 DEBUG Registry keys for service AvgLdx86 are not present
2010-10-14 18:43:58,546 DEBUG Registry keys for service AvgLdx64 are not present
2010-10-14 18:43:58,546 DEBUG Registry keys for service AvgTdiX are not present
2010-10-14 18:43:58,546 DEBUG Registry keys for service AvgTdiA are not present
2010-10-14 18:43:58,546 DEBUG Registry keys for service AvgRkx86 are not present
2010-10-14 18:43:58,546 DEBUG Registry keys for service AvgRkx64 are not present
2010-10-14 18:43:58,546 DEBUG Registry keys for service avg9emc are not present
2010-10-14 18:43:58,546 DEBUG Registry keys for service avgfws9 are not present
2010-10-14 18:43:58,546 DEBUG Registry keys for service avgfws are not present
2010-10-14 18:43:58,546 DEBUG Registry keys for service AVGIDSAgent are not present
2010-10-14 18:43:58,546 DEBUG Registry keys for service AVGIDSShimxpx are not present
2010-10-14 18:43:58,546 DEBUG Registry keys for service AVGIDSFilterxpx are not present
2010-10-14 18:43:58,546 DEBUG Registry keys for service AVGIDSDriverxpx are not present
2010-10-14 18:43:58,546 DEBUG Registry keys for service AVGIDSShimvtx are not present
2010-10-14 18:43:58,546 DEBUG Registry keys for service AVGIDSFiltervtx are not present
2010-10-14 18:43:58,546 DEBUG Registry keys for service AVGIDSDrivervtx are not present
2010-10-14 18:43:58,546 DEBUG Registry keys for service AVGIDSFiltervta are not present
2010-10-14 18:43:58,546 DEBUG Registry keys for service AVGIDSDrivervta are not present
2010-10-14 18:43:58,546 DEBUG Service AVGIDSShimw7x RegCleanup
2010-10-14 18:43:58,546 DEBUG Registry keys for service AVGIDSShimw7x are not present
2010-10-14 18:43:58,546 DEBUG Service AVGIDSFilterw7x RegCleanup
2010-10-14 18:43:58,546 DEBUG Registry keys for service AVGIDSFilterw7x are not present
2010-10-14 18:43:58,546 DEBUG Service AVGIDSDriverw7x RegCleanup
2010-10-14 18:43:58,546 DEBUG Registry keys for service AVGIDSDriverw7x are not present
2010-10-14 18:43:58,546 DEBUG Service AVGIDSFilterw7a RegCleanup
2010-10-14 18:43:58,546 DEBUG Registry keys for service AVGIDSFilterw7a are not present
2010-10-14 18:43:58,546 DEBUG Service AVGIDSDriverw7a RegCleanup
2010-10-14 18:43:58,546 DEBUG Registry keys for service AVGIDSDriverw7a are not present
2010-10-14 18:43:58,546 DEBUG Service AVGIDSErHrxpx RegCleanup
2010-10-14 18:43:58,546 DEBUG Registry keys for service AVGIDSErHrxpx are not present
2010-10-14 18:43:58,546 DEBUG Service AVGIDSErHrvtx RegCleanup
2010-10-14 18:43:58,546 DEBUG Registry keys for service AVGIDSErHrvtx are not present
2010-10-14 18:43:58,546 DEBUG Service AVGIDSErHrvta RegCleanup
2010-10-14 18:43:58,546 DEBUG Registry keys for service AVGIDSErHrvta are not present
2010-10-14 18:43:58,546 DEBUG Service AVGIDSErHrw7x RegCleanup
2010-10-14 18:43:58,546 DEBUG Registry keys for service AVGIDSErHrw7x are not present
2010-10-14 18:43:58,546 DEBUG Service AVGIDSErHrw7a RegCleanup
2010-10-14 18:43:58,546 DEBUG Registry keys for service AVGIDSErHrw7a are not present
2010-10-14 18:43:58,546 DEBUG Service avgwd RegCleanup
2010-10-14 18:43:58,562 DEBUG Registry keys for service avgwd are not present
2010-10-14 18:43:58,562 DEBUG Service AvgAdminServer RegCleanup
2010-10-14 18:43:58,562 DEBUG Registry keys for service AvgAdminServer are not present
2010-10-14 18:43:58,562 INFO ***** Avg Fw NDIS driver(separate process) *****
2010-10-14 18:43:58,578 DEBUG Avg9Uninstall\Directories key failed to open (error: e0010013)
2010-10-14 18:43:58,578 DEBUG Avg8Uninstall\Directories key failed to open (error: e0010013)
2010-10-14 18:43:58,578 DEBUG Reading HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion:ProgramFilesDir (x86) value failed (error: e001003d)
2010-10-14 18:43:58,578 INFO Command line: "C:\AVGTemp\avg2011remover_en\avgremoverx.exe" /ndisonly /skipask
2010-10-14 18:43:58,750 WARN AvgDir param empty.
2010-10-14 18:43:58,750 WARN AvgAdminDir param empty.
2010-10-14 18:43:58,750 WARN AvgDataDir param empty.
2010-10-14 18:43:58,765 INFO AvgRemover runs in attempt number 1
2010-10-14 18:43:58,765 INFO ***** Avg Fw NDIS driver *****
2010-10-14 18:43:58,765 INFO ...this operation can take several minutes...
2010-10-14 18:43:59,984 INFO FW NDIS driver not present
2010-10-14 18:44:00,093 DEBUG Remove NDIS driver pass, next uninstalation step is 10, old was 1
2010-10-14 18:44:00,093 INFO ***** end of Fw NDIS separated process *****
2010-10-14 18:44:00,093 INFO ***** Drivers *****
2010-10-14 18:44:00,109 INFO ***** Running AVG process *****
2010-10-14 18:44:01,375 INFO ***** Registry keys and values *****
2010-10-14 18:44:01,375 INFO Processing registry SOFTWARE\Mozilla\Firefox\Extensions
2010-10-14 18:44:01,375 DEBUG Value SOFTWARE\Mozilla\Firefox\Extensions:{3f963a5b-e555-4543-90e2-c3908898db71} Remove
2010-10-14 18:44:01,375 INFO Value SOFTWARE\Mozilla\Firefox\Extensions:{3f963a5b-e555-4543-90e2-c3908898db71} is not present
2010-10-14 18:44:01,390 DEBUG Value SOFTWARE\Mozilla\Firefox\Extensions:{1d5287d1-8a92-0001-1f31-1cec198018d8} Remove
2010-10-14 18:44:01,390 INFO Value SOFTWARE\Mozilla\Firefox\Extensions:{1d5287d1-8a92-0001-1f31-1cec198018d8} is not present
2010-10-14 18:44:01,390 INFO Processing registry SYSTEM\CurrentControlSet\Services\Eventlog\Application\Avg8Alrt
2010-10-14 18:44:01,390 DEBUG Key SYSTEM\CurrentControlSet\Services\Eventlog\Application\Avg8Alrt ForceRemove
2010-10-14 18:44:01,390 DEBUG Key SYSTEM\CurrentControlSet\Services\Eventlog\Application\Avg8Alrt not found
2010-10-14 18:44:01,390 INFO Processing registry SYSTEM\CurrentControlSet\Services\Eventlog\Application\Avg9Alrt
2010-10-14 18:44:01,390 DEBUG Key SYSTEM\CurrentControlSet\Services\Eventlog\Application\Avg9Alrt ForceRemove
2010-10-14 18:44:01,390 DEBUG Key SYSTEM\CurrentControlSet\Services\Eventlog\Application\Avg9Alrt not found
2010-10-14 18:44:01,390 INFO Processing registry SYSTEM\CurrentControlSet\Services\Eventlog\Application\AvgEms
2010-10-14 18:44:01,406 DEBUG Key SYSTEM\CurrentControlSet\Services\Eventlog\Application\AvgEms ForceRemove
2010-10-14 18:44:01,406 DEBUG Key SYSTEM\CurrentControlSet\Services\Eventlog\Application\AvgEms not found
2010-10-14 18:44:01,406 INFO Processing registry SYSTEM\CurrentControlSet\Services\Avg
2010-10-14 18:44:01,406 DEBUG Key SYSTEM\CurrentControlSet\Services\Avg ForceRemove
2010-10-14 18:44:01,406 DEBUG Key SYSTEM\CurrentControlSet\Services\Avg not found
2010-10-14 18:44:01,406 INFO Processing registry SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{B2AF1721-312E-4B07-8B17-CEB780DCD054}
2010-10-14 18:44:01,406 DEBUG Key SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{B2AF1721-312E-4B07-8B17-CEB780DCD054} ForceRemove
2010-10-14 18:44:01,406 DEBUG Key SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{B2AF1721-312E-4B07-8B17-CEB780DCD054} not found
2010-10-14 18:44:01,406 INFO Processing registry SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{CCC7A320-B3CA-4199-B1A6-9F516DD69829}
2010-10-14 18:44:01,421 DEBUG Key SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{CCC7A320-B3CA-4199-B1A6-9F516DD69829} ForceRemove
2010-10-14 18:44:01,421 DEBUG Key SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{CCC7A320-B3CA-4199-B1A6-9F516DD69829} not found
2010-10-14 18:44:01,421 INFO Processing registry SOFTWARE\Microsoft\Internet Explorer\Toolbar
2010-10-14 18:44:01,421 DEBUG Value SOFTWARE\Microsoft\Internet Explorer\Toolbar:{CCC7A320-B3CA-4199-B1A6-9F516DD69829} Remove
2010-10-14 18:44:01,421 DEBUG Value SOFTWARE\Microsoft\Internet Explorer\Toolbar:{CCC7A320-B3CA-4199-B1A6-9F516DD69829} not present - Key not found
2010-10-14 18:44:01,421 INFO Processing registry SOFTWARE\Microsoft\Internet Explorer\SearchScopes\{CCC7A320-B3CA-4199-B1A6-9F516DD69829}
2010-10-14 18:44:01,421 DEBUG Key SOFTWARE\Microsoft\Internet Explorer\SearchScopes\{CCC7A320-B3CA-4199-B1A6-9F516DD69829} ForceRemove
2010-10-14 18:44:01,421 DEBUG Key SOFTWARE\Microsoft\Internet Explorer\SearchScopes\{CCC7A320-B3CA-4199-B1A6-9F516DD69829} not found
2010-10-14 18:44:01,421 INFO Processing registry SOFTWARE\Microsoft\Exchange\Client\Extensions
2010-10-14 18:44:01,421 DEBUG Value SOFTWARE\Microsoft\Exchange\Client\Extensions:Outlook Setup Extension Remove
2010-10-14 18:44:01,437 INFO Value SOFTWARE\Microsoft\Exchange\Client\Extensions:Outlook Setup Extension is not present
2010-10-14 18:44:01,453 INFO Processing registry SOFTWARE\Microsoft\Exchange\Client\Extensions
2010-10-14 18:44:01,453 DEBUG Value SOFTWARE\Microsoft\Exchange\Client\Extensions:AVG Exchange Extension Remove
2010-10-14 18:44:01,453 INFO Value SOFTWARE\Microsoft\Exchange\Client\Extensions:AVG Exchange Extension is not present
2010-10-14 18:44:01,453 INFO Processing registry SOFTWARE\Microsoft\Windows NT\CurrentVersion\Windows
2010-10-14 18:44:01,453 DEBUG Value SOFTWARE\Microsoft\Windows NT\CurrentVersion\Windows:AppInit_DLLs Modify
2010-10-14 18:44:01,453 DEBUG Value SOFTWARE\Microsoft\Windows NT\CurrentVersion\Windows:AppInit_DLLs doesn't need to be modified
2010-10-14 18:44:01,453 INFO Processing registry SOFTWARE\Microsoft\Windows\CurrentVersion\Shell Extensions\Approved
2010-10-14 18:44:01,468 DEBUG Value SOFTWARE\Microsoft\Windows\CurrentVersion\Shell Extensions\Approved:{9F97547E-460A-42C5-AE0C-81C61FFAEBC3} Remove
2010-10-14 18:44:01,484 INFO Value SOFTWARE\Microsoft\Windows\CurrentVersion\Shell Extensions\Approved:{9F97547E-460A-42C5-AE0C-81C61FFAEBC3} is not present
2010-10-14 18:44:01,484 INFO Processing registry SOFTWARE\Microsoft\Windows\CurrentVersion\Shell Extensions\Approved
2010-10-14 18:44:01,484 DEBUG Value SOFTWARE\Microsoft\Windows\CurrentVersion\Shell Extensions\Approved:{9F97547E-460A-42C5-AE0C-81C61FFAEBC3} Remove
2010-10-14 18:44:01,500 DEBUG Value SOFTWARE\Microsoft\Windows\CurrentVersion\Shell Extensions\Approved:{9F97547E-4609-42C5-AE0C-81C61FFAEBC3} Remove
2010-10-14 18:44:01,500 INFO Value SOFTWARE\Microsoft\Windows\CurrentVersion\Shell Extensions\Approved:{9F97547E-4609-42C5-AE0C-81C61FFAEBC3} is not present
2010-10-14 18:44:01,500 INFO Processing registry SOFTWARE\Microsoft\Windows\CurrentVersion\Shell Extensions\Approved
2010-10-14 18:44:01,500 INFO Processing registry SOFTWARE\Microsoft\Windows\CurrentVersion\Run
2010-10-14 18:44:01,515 DEBUG Value SOFTWARE\Microsoft\Windows\CurrentVersion\Run:AVG8_TRAY Remove
2010-10-14 18:44:01,515 INFO Value SOFTWARE\Microsoft\Windows\CurrentVersion\Run:AVG8_TRAY is not present
2010-10-14 18:44:01,515 INFO Processing registry SOFTWARE\Microsoft\Windows\CurrentVersion\Run
2010-10-14 18:44:01,515 DEBUG Value SOFTWARE\Microsoft\Windows\CurrentVersion\Run:AVG9_TRAY Remove
2010-10-14 18:44:01,515 INFO Value SOFTWARE\Microsoft\Windows\CurrentVersion\Run:AVG9_TRAY is not present
2010-10-14 18:44:01,531 INFO Processing registry SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\AVG8Uninstall
2010-10-14 18:44:01,531 DEBUG Key SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\AVG8Uninstall ForceRemove
2010-10-14 18:44:01,531 DEBUG Key SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\AVG8Uninstall not found
2010-10-14 18:44:01,531 INFO Processing registry SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\AVG7Uninstall
2010-10-14 18:44:01,531 DEBUG Key SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\AVG7Uninstall ForceRemove
2010-10-14 18:44:01,531 DEBUG Key SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\AVG7Uninstall not found
2010-10-14 18:44:01,531 INFO Processing registry SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\AVG9Uninstall
2010-10-14 18:44:01,531 DEBUG Key SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\AVG9Uninstall ForceRemove
2010-10-14 18:44:01,531 DEBUG Key SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\AVG9Uninstall not found
2010-10-14 18:44:01,531 INFO Processing registry SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{A3BC75A2-1F87-4686-AA43-5347D756017C}
2010-10-14 18:44:01,546 DEBUG Key SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{A3BC75A2-1F87-4686-AA43-5347D756017C} ForceRemove
2010-10-14 18:44:01,546 DEBUG Key SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{A3BC75A2-1F87-4686-AA43-5347D756017C} not found
2010-10-14 18:44:01,546 INFO Processing registry SOFTWARE\Classes\CLSID\{9F97547E-4609-42C5-AE0C-81C61FFAEBC3}
2010-10-14 18:44:01,546 DEBUG Key SOFTWARE\Classes\CLSID\{9F97547E-4609-42C5-AE0C-81C61FFAEBC3} ForceRemove
2010-10-14 18:44:01,546 DEBUG Key SOFTWARE\Classes\CLSID\{9F97547E-4609-42C5-AE0C-81C61FFAEBC3} not found
2010-10-14 18:44:01,546 INFO Processing registry SOFTWARE\Classes\CLSID\{6E801D47-45B7-4D10-8268-DBBD5C233F82}
2010-10-14 18:44:01,546 DEBUG Key SOFTWARE\Classes\CLSID\{6E801D47-45B7-4D10-8268-DBBD5C233F82} ForceRemove
2010-10-14 18:44:01,546 DEBUG Key SOFTWARE\Classes\CLSID\{6E801D47-45B7-4D10-8268-DBBD5C233F82} not found
2010-10-14 18:44:01,562 DEBUG Key SOFTWARE\Classes\CLSID\{6E801D47-45B7-4D10-8268-DBBD5C233F82} ForceRemove
2010-10-14 18:44:01,562 DEBUG Key SOFTWARE\Classes\CLSID\{6E801D47-45B7-4D10-8268-DBBD5C233F82} not found
2010-10-14 18:44:01,562 INFO Processing registry SOFTWARE\Classes\AvgDiagFile
2010-10-14 18:44:01,562 DEBUG Key SOFTWARE\Classes\AvgDiagFile ForceRemove
2010-10-14 18:44:01,562 DEBUG Key SOFTWARE\Classes\AvgDiagFile not found
2010-10-14 18:44:01,562 INFO Processing registry SOFTWARE\Classes\.avgdi
2010-10-14 18:44:01,562 DEBUG Key SOFTWARE\Classes\.avgdi ForceRemove
2010-10-14 18:44:01,562 DEBUG Key SOFTWARE\Classes\.avgdi not found
2010-10-14 18:44:01,562 INFO Processing registry SOFTWARE\Classes\.avgdx
2010-10-14 18:44:01,562 DEBUG Key SOFTWARE\Classes\.avgdx ForceRemove
2010-10-14 18:44:01,562 DEBUG Key SOFTWARE\Classes\.avgdx not found
2010-10-14 18:44:01,578 DEBUG Key SOFTWARE\Classes\.avgdx ForceRemove
2010-10-14 18:44:01,578 DEBUG Key SOFTWARE\Classes\.avgdx not found
2010-10-14 18:44:01,578 INFO Processing registry SOFTWARE\Classes\.avgdx
2010-10-14 18:44:01,578 INFO Processing registry SOFTWARE\Classes\piffile\shellex\ContextMenuHandlers\AVG8 Shell Extension
2010-10-14 18:44:01,578 DEBUG Key SOFTWARE\Classes\piffile\shellex\ContextMenuHandlers\AVG8 Shell Extension ForceRemove
2010-10-14 18:44:01,578 DEBUG Key SOFTWARE\Classes\piffile\shellex\ContextMenuHandlers\AVG8 Shell Extension not found
2010-10-14 18:44:01,578 INFO Processing registry SOFTWARE\Classes\Folder\shellex\ContextMenuHandlers\AVG8 Shell Extension
2010-10-14 18:44:01,578 DEBUG Key SOFTWARE\Classes\Folder\shellex\ContextMenuHandlers\AVG8 Shell Extension ForceRemove
2010-10-14 18:44:01,593 DEBUG Key SOFTWARE\Classes\Folder\shellex\ContextMenuHandlers\AVG8 Shell Extension not found
2010-10-14 18:44:01,593 INFO Processing registry SOFTWARE\Classes\*\shellex\ContextMenuHandlers\AVG8 Shell Extension
2010-10-14 18:44:01,593 DEBUG Key SOFTWARE\Classes\*\shellex\ContextMenuHandlers\AVG8 Shell Extension ForceRemove
2010-10-14 18:44:01,593 DEBUG Key SOFTWARE\Classes\*\shellex\ContextMenuHandlers\AVG8 Shell Extension not found
2010-10-14 18:44:01,593 INFO Processing registry SOFTWARE\Classes\*\shellex\ContextMenuHandlers\AVG9 Shell Extension
2010-10-14 18:44:01,593 DEBUG Key SOFTWARE\Classes\*\shellex\ContextMenuHandlers\AVG9 Shell Extension ForceRemove
2010-10-14 18:44:01,593 DEBUG Key SOFTWARE\Classes\*\shellex\ContextMenuHandlers\AVG9 Shell Extension not found
2010-10-14 18:44:01,593 INFO Processing registry SOFTWARE\Classes\Folder\ShellEx\ContextMenuHandlers\AVG9 Shell Extension
2010-10-14 18:44:01,593 DEBUG Key SOFTWARE\Classes\Folder\ShellEx\ContextMenuHandlers\AVG9 Shell Extension ForceRemove
2010-10-14 18:44:01,593 DEBUG Key SOFTWARE\Classes\Folder\ShellEx\ContextMenuHandlers\AVG9 Shell Extension not found
2010-10-14 18:44:01,609 DEBUG Key SOFTWARE\Classes\Folder\ShellEx\ContextMenuHandlers\AVG9 Shell Extension ForceRemove
2010-10-14 18:44:01,609 DEBUG Key SOFTWARE\Classes\Folder\ShellEx\ContextMenuHandlers\AVG9 Shell Extension not found
2010-10-14 18:44:01,609 INFO Processing registry SOFTWARE\Classes\piffile\shellex\ContextMenuHandlers\AVG9 Shell Extension
2010-10-14 18:44:01,609 DEBUG Key SOFTWARE\Classes\piffile\shellex\ContextMenuHandlers\AVG9 Shell Extension ForceRemove
2010-10-14 18:44:01,609 DEBUG Key SOFTWARE\Classes\piffile\shellex\ContextMenuHandlers\AVG9 Shell Extension not found
2010-10-14 18:44:01,609 INFO Processing registry SOFTWARE\Classes\PROTOCOLS\Handler\linkscanner
2010-10-14 18:44:01,625 DEBUG Key SOFTWARE\Classes\PROTOCOLS\Handler\linkscanner ForceRemove
2010-10-14 18:44:01,625 DEBUG Key SOFTWARE\Classes\PROTOCOLS\Handler\linkscanner not found
2010-10-14 18:44:01,625 INFO Processing registry SOFTWARE\Classes\PROTOCOLS\Handler\linkscanner
2010-10-14 18:44:01,625 INFO Processing registry SOFTWARE\Classes\avgsbg.state
2010-10-14 18:44:01,625 DEBUG Key SOFTWARE\Classes\avgsbg.state ForceRemove
2010-10-14 18:44:01,625 DEBUG Key SOFTWARE\Classes\avgsbg.state not found
2010-10-14 18:44:01,625 INFO Processing registry SOFTWARE\Classes\avgsbg.state.1
2010-10-14 18:44:01,625 DEBUG Key SOFTWARE\Classes\avgsbg.state.1 ForceRemove
2010-10-14 18:44:01,625 DEBUG Key SOFTWARE\Classes\avgsbg.state.1 not found
2010-10-14 18:44:01,640 DEBUG Key SOFTWARE\Classes\avgsbg.state.1 ForceRemove
2010-10-14 18:44:01,640 DEBUG Key SOFTWARE\Classes\avgsbg.state.1 not found
2010-10-14 18:44:01,640 INFO Processing registry SOFTWARE\Classes\LinkScannerIE.NavFilter
2010-10-14 18:44:01,640 DEBUG Key SOFTWARE\Classes\LinkScannerIE.NavFilter ForceRemove
2010-10-14 18:44:01,656 DEBUG Key SOFTWARE\Classes\LinkScannerIE.NavFilter not found
2010-10-14 18:44:01,656 INFO Processing registry SOFTWARE\Classes\LinkScannerIE.NavFilter
2010-10-14 18:44:01,656 DEBUG Key SOFTWARE\Classes\LinkScannerIE.NavFilter ForceRemove
2010-10-14 18:44:01,656 INFO Processing registry SOFTWARE\Classes\LinkScannerIE.NavFilter.1
2010-10-14 18:44:01,671 DEBUG Key SOFTWARE\Classes\LinkScannerIE.NavFilter.1 ForceRemove
2010-10-14 18:44:01,671 DEBUG Key SOFTWARE\Classes\LinkScannerIE.NavFilter.1 not found
2010-10-14 18:44:01,671 INFO Processing registry SOFTWARE\Classes\LinkScannerIE.NavFilter.1
2010-10-14 18:44:01,671 INFO Processing registry SOFTWARE\Classes\MicroScanner.MicroScanner
2010-10-14 18:44:01,671 DEBUG Key SOFTWARE\Classes\MicroScanner.MicroScanner ForceRemove
2010-10-14 18:44:01,671 DEBUG Key SOFTWARE\Classes\MicroScanner.MicroScanner not found
2010-10-14 18:44:01,687 DEBUG Key SOFTWARE\Classes\MicroScanner.MicroScanner ForceRemove
2010-10-14 18:44:01,687 DEBUG Key SOFTWARE\Classes\MicroScanner.MicroScanner not found
2010-10-14 18:44:01,687 INFO Processing registry SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\AVGSE.DLL
2010-10-14 18:44:01,687 DEBUG Key SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\AVGSE.DLL ForceRemove
2010-10-14 18:44:01,687 DEBUG Key SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\AVGSE.DLL not found
2010-10-14 18:44:01,687 INFO Processing registry SOFTWARE\Microsoft\Windows\CurrentVersion\Run
2010-10-14 18:44:01,687 DEBUG Value SOFTWARE\Microsoft\Windows\CurrentVersion\Run:AVG_TRAY Remove
2010-10-14 18:44:01,687 INFO Value SOFTWARE\Microsoft\Windows\CurrentVersion\Run:AVG_TRAY is not present
2010-10-14 18:44:01,703 DEBUG Value SOFTWARE\Microsoft\Windows\CurrentVersion\Run:AVG_TRAY Remove
2010-10-14 18:44:01,703 INFO Value SOFTWARE\Microsoft\Windows\CurrentVersion\Run:AVG_TRAY is not present
2010-10-14 18:44:01,703 INFO Processing registry SOFTWARE\Classes\AppID\avgsbg.DLL
2010-10-14 18:44:01,703 DEBUG Key SOFTWARE\Classes\AppID\avgsbg.DLL ForceRemove
2010-10-14 18:44:01,703 DEBUG Key SOFTWARE\Classes\AppID\avgsbg.DLL not found
2010-10-14 18:44:01,703 INFO Processing registry SYSTEM\ControlSet001\Control\GroupOrderList
2010-10-14 18:44:01,718 DEBUG Value SYSTEM\ControlSet001\Control\GroupOrderList:AVG Remove
2010-10-14 18:44:01,734 INFO Processing registry SYSTEM\ControlSet001\services\Avg
2010-10-14 18:44:01,734 DEBUG Key SYSTEM\ControlSet001\services\Avg ForceRemove
2010-10-14 18:44:01,734 DEBUG Key SYSTEM\ControlSet001\services\Avg not found
2010-10-14 18:44:01,734 INFO Processing registry SYSTEM\ControlSet001\services\Avgfwfd
2010-10-14 18:44:01,734 DEBUG Key SYSTEM\ControlSet001\services\Avgfwfd ForceRemove
2010-10-14 18:44:01,734 DEBUG Key SYSTEM\ControlSet001\services\Avgfwfd not found
2010-10-14 18:44:01,734 INFO Processing registry SYSTEM\ControlSet001\services\AVG Security Toolbar Service
2010-10-14 18:44:01,734 DEBUG Key SYSTEM\ControlSet001\services\AVG Security Toolbar Service ForceRemove
2010-10-14 18:44:01,750 DEBUG Key SYSTEM\ControlSet001\services\AVG Security Toolbar Service not found
2010-10-14 18:44:01,750 INFO Processing registry SYSTEM\ControlSet001\services\Avgfws
2010-10-14 18:44:01,750 DEBUG Key SYSTEM\ControlSet001\services\Avgfws ForceRemove
2010-10-14 18:44:01,750 DEBUG Key SYSTEM\ControlSet001\services\Avgfws not found
2010-10-14 18:44:01,750 INFO Processing registry SYSTEM\ControlSet001\services\AVGIDSAgent
2010-10-14 18:44:01,750 DEBUG Key SYSTEM\ControlSet001\services\AVGIDSAgent ForceRemove
2010-10-14 18:44:01,750 DEBUG Key SYSTEM\ControlSet001\services\AVGIDSAgent not found
2010-10-14 18:44:01,750 INFO Processing registry SYSTEM\ControlSet001\services\AVGIDSDriver
2010-10-14 18:44:01,750 DEBUG Key SYSTEM\ControlSet001\services\AVGIDSDriver ForceRemove
2010-10-14 18:44:01,750 DEBUG Key SYSTEM\ControlSet001\services\AVGIDSDriver not found
2010-10-14 18:44:01,750 INFO Processing registry SYSTEM\ControlSet001\services\AVGIDSEH
2010-10-14 18:44:01,765 DEBUG Key SYSTEM\ControlSet001\services\AVGIDSEH ForceRemove
2010-10-14 18:44:01,765 DEBUG Key SYSTEM\ControlSet001\services\AVGIDSEH not found
2010-10-14 18:44:01,765 INFO Processing registry SYSTEM\ControlSet001\services\AVGIDSFilter
2010-10-14 18:44:01,765 DEBUG Key SYSTEM\ControlSet001\services\AVGIDSFilter ForceRemove
2010-10-14 18:44:01,765 DEBUG Key SYSTEM\ControlSet001\services\AVGIDSFilter not found
2010-10-14 18:44:01,765 INFO Processing registry SYSTEM\ControlSet001\services\avgldx64
2010-10-14 18:44:01,765 DEBUG Key SYSTEM\ControlSet001\services\avgldx64 ForceRemove
2010-10-14 18:44:01,765 DEBUG Key SYSTEM\ControlSet001\services\avgldx64 not found
2010-10-14 18:44:01,765 INFO Processing registry SYSTEM\ControlSet001\services\avgldx86
2010-10-14 18:44:01,765 DEBUG Key SYSTEM\ControlSet001\services\avgldx86 ForceRemove
2010-10-14 18:44:01,765 DEBUG Key SYSTEM\ControlSet001\services\avgldx86 not found
2010-10-14 18:44:01,765 INFO Processing registry SYSTEM\ControlSet001\services\avgmfx64
2010-10-14 18:44:01,781 DEBUG Key SYSTEM\ControlSet001\services\avgmfx64 ForceRemove
2010-10-14 18:44:01,781 DEBUG Key SYSTEM\ControlSet001\services\avgmfx64 not found
2010-10-14 18:44:01,781 INFO Processing registry SYSTEM\ControlSet001\services\avgmfx86
2010-10-14 18:44:01,781 DEBUG Key SYSTEM\ControlSet001\services\avgmfx86 ForceRemove
2010-10-14 18:44:01,781 DEBUG Key SYSTEM\ControlSet001\services\avgmfx86 not found
2010-10-14 18:44:01,781 INFO Processing registry SYSTEM\ControlSet001\services\avgrkx64
2010-10-14 18:44:01,781 DEBUG Key SYSTEM\ControlSet001\services\avgrkx64 ForceRemove
2010-10-14 18:44:01,781 DEBUG Key SYSTEM\ControlSet001\services\avgrkx64 not found
2010-10-14 18:44:01,781 INFO Processing registry SYSTEM\ControlSet001\services\avgrkx86
2010-10-14 18:44:01,781 DEBUG Key SYSTEM\ControlSet001\services\avgrkx86 ForceRemove
2010-10-14 18:44:01,781 DEBUG Key SYSTEM\ControlSet001\services\avgrkx86 not found
2010-10-14 18:44:01,781 INFO Processing registry SYSTEM\ControlSet001\services\avgtdia
2010-10-14 18:44:01,781 DEBUG Key SYSTEM\ControlSet001\services\avgtdia ForceRemove
2010-10-14 18:44:01,781 DEBUG Key SYSTEM\ControlSet001\services\avgtdia not found
2010-10-14 18:44:01,781 INFO Processing registry SYSTEM\ControlSet001\services\avgtdix
2010-10-14 18:44:01,796 DEBUG Key SYSTEM\ControlSet001\services\avgtdix ForceRemove
2010-10-14 18:44:01,796 DEBUG Key SYSTEM\ControlSet001\services\avgtdix not found
2010-10-14 18:44:01,796 INFO Processing registry SYSTEM\ControlSet001\services\avgwd
2010-10-14 18:44:01,796 DEBUG Key SYSTEM\ControlSet001\services\avgwd ForceRemove
2010-10-14 18:44:01,796 DEBUG Key SYSTEM\ControlSet001\services\avgwd not found
2010-10-14 18:44:01,796 INFO Processing registry SYSTEM\ControlSet001\services\avgfwdx
2010-10-14 18:44:01,796 DEBUG Key SYSTEM\ControlSet001\services\avgfwdx ForceRemove
2010-10-14 18:44:01,796 DEBUG Key SYSTEM\ControlSet001\services\avgfwdx not found
2010-10-14 18:44:01,796 INFO Processing registry SYSTEM\ControlSet001\services\avgfwda
2010-10-14 18:44:01,796 DEBUG Key SYSTEM\ControlSet001\services\avgfwda ForceRemove
2010-10-14 18:44:01,796 DEBUG Key SYSTEM\ControlSet001\services\avgfwda not found
2010-10-14 18:44:01,796 INFO Processing registry SYSTEM\ControlSet002\services\Avg
2010-10-14 18:44:01,812 DEBUG Key SYSTEM\ControlSet002\services\Avg ForceRemove
2010-10-14 18:44:01,828 DEBUG Key SYSTEM\ControlSet002\services\Avg not found
2010-10-14 18:44:01,828 INFO Processing registry SYSTEM\ControlSet002\services\Avgfwfd
2010-10-14 18:44:01,828 DEBUG Key SYSTEM\ControlSet002\services\Avgfwfd ForceRemove
2010-10-14 18:44:01,828 DEBUG Key SYSTEM\ControlSet002\services\Avgfwfd not found
2010-10-14 18:44:01,828 INFO Processing registry SYSTEM\ControlSet002\services\AVG Security Toolbar Service
2010-10-14 18:44:01,843 DEBUG Key SYSTEM\ControlSet002\services\AVG Security Toolbar Service ForceRemove
2010-10-14 18:44:01,843 DEBUG Key SYSTEM\ControlSet002\services\AVG Security Toolbar Service not found
2010-10-14 18:44:01,843 INFO Processing registry SYSTEM\ControlSet002\services\Avgfws
2010-10-14 18:44:01,843 DEBUG Key SYSTEM\ControlSet002\services\Avgfws ForceRemove
2010-10-14 18:44:01,843 DEBUG Key SYSTEM\ControlSet002\services\Avgfws not found
2010-10-14 18:44:01,843 INFO Processing registry SYSTEM\ControlSet002\services\AVGIDSAgent
2010-10-14 18:44:01,843 DEBUG Key SYSTEM\ControlSet002\services\AVGIDSAgent ForceRemove
2010-10-14 18:44:01,843 DEBUG Key SYSTEM\ControlSet002\services\AVGIDSAgent not found
2010-10-14 18:44:01,843 INFO Processing registry SYSTEM\ControlSet002\services\AVGIDSDriver
2010-10-14 18:44:01,843 DEBUG Key SYSTEM\ControlSet002\services\AVGIDSDriver ForceRemove
2010-10-14 18:44:01,843 DEBUG Key SYSTEM\ControlSet002\services\AVGIDSDriver not found
2010-10-14 18:44:01,843 INFO Processing registry SYSTEM\ControlSet002\services\AVGIDSEH
2010-10-14 18:44:01,859 DEBUG Key SYSTEM\ControlSet002\services\AVGIDSEH ForceRemove
2010-10-14 18:44:01,859 DEBUG Key SYSTEM\ControlSet002\services\AVGIDSEH not found
2010-10-14 18:44:01,859 INFO Processing registry SYSTEM\ControlSet002\services\AVGIDSFilter
2010-10-14 18:44:01,859 DEBUG Key SYSTEM\ControlSet002\services\AVGIDSFilter ForceRemove
2010-10-14 18:44:01,859 DEBUG Key SYSTEM\ControlSet002\services\AVGIDSFilter not found
2010-10-14 18:44:01,859 INFO Processing registry SYSTEM\ControlSet002\services\avgldx64
2010-10-14 18:44:01,859 DEBUG Key SYSTEM\ControlSet002\services\avgldx64 ForceRemove
2010-10-14 18:44:01,859 DEBUG Key SYSTEM\ControlSet002\services\avgldx64 not found
2010-10-14 18:44:01,859 INFO Processing registry SYSTEM\ControlSet002\services\avgldx86
2010-10-14 18:44:01,859 DEBUG Key SYSTEM\ControlSet002\services\avgldx86 ForceRemove
2010-10-14 18:44:01,859 DEBUG Key SYSTEM\ControlSet002\services\avgldx86 not found
2010-10-14 18:44:01,859 INFO Processing registry SYSTEM\ControlSet002\services\avgmfx64
2010-10-14 18:44:01,875 DEBUG Key SYSTEM\ControlSet002\services\avgmfx64 ForceRemove
2010-10-14 18:44:01,875 DEBUG Key SYSTEM\ControlSet002\services\avgmfx64 not found
2010-10-14 18:44:01,875 INFO Processing registry SYSTEM\ControlSet002\services\avgmfx86
2010-10-14 18:44:01,875 DEBUG Key SYSTEM\ControlSet002\services\avgmfx86 ForceRemove
2010-10-14 18:44:01,875 DEBUG Key SYSTEM\ControlSet002\services\avgmfx86 not found
2010-10-14 18:44:01,875 INFO Processing registry SYSTEM\ControlSet002\services\avgrkx64
2010-10-14 18:44:01,875 DEBUG Key SYSTEM\ControlSet002\services\avgrkx64 ForceRemove
2010-10-14 18:44:01,875 DEBUG Key SYSTEM\ControlSet002\services\avgrkx64 not found
2010-10-14 18:44:01,875 INFO Processing registry SYSTEM\ControlSet002\services\avgrkx86
2010-10-14 18:44:01,875 DEBUG Key SYSTEM\ControlSet002\services\avgrkx86 ForceRemove
2010-10-14 18:44:01,875 DEBUG Key SYSTEM\ControlSet002\services\avgrkx86 not found
2010-10-14 18:44:01,875 INFO Processing registry SYSTEM\ControlSet002\services\avgtdia
2010-10-14 18:44:01,890 DEBUG Key SYSTEM\ControlSet002\services\avgtdia ForceRemove
2010-10-14 18:44:01,890 DEBUG Key SYSTEM\ControlSet002\services\avgtdia not found
2010-10-14 18:44:01,890 INFO Processing registry SYSTEM\ControlSet002\services\avgtdix
2010-10-14 18:44:01,890 DEBUG Key SYSTEM\ControlSet002\services\avgtdix ForceRemove
2010-10-14 18:44:01,890 DEBUG Key SYSTEM\ControlSet002\services\avgtdix not found
2010-10-14 18:44:01,890 INFO Processing registry SYSTEM\ControlSet002\services\avgwd
2010-10-14 18:44:01,890 DEBUG Key SYSTEM\ControlSet002\services\avgwd ForceRemove
2010-10-14 18:44:01,890 DEBUG Key SYSTEM\ControlSet002\services\avgwd not found
2010-10-14 18:44:01,890 INFO Processing registry SYSTEM\ControlSet002\services\avgfwdx
2010-10-14 18:44:01,890 DEBUG Key SYSTEM\ControlSet002\services\avgfwdx ForceRemove
2010-10-14 18:44:01,890 DEBUG Key SYSTEM\ControlSet002\services\avgfwdx not found
2010-10-14 18:44:01,890 INFO Processing registry SYSTEM\ControlSet002\services\avgfwda
2010-10-14 18:44:01,906 DEBUG Key SYSTEM\ControlSet002\services\avgfwda ForceRemove
2010-10-14 18:44:01,906 DEBUG Key SYSTEM\ControlSet002\services\avgfwda not found
2010-10-14 18:44:01,906 INFO Processing registry SYSTEM\ControlSet002\services\Avg
2010-10-14 18:44:01,906 DEBUG Key SYSTEM\ControlSet002\services\Avg ForceRemove
2010-10-14 18:44:01,906 DEBUG Key SYSTEM\ControlSet002\services\Avg not found
2010-10-14 18:44:01,906 INFO Processing registry SYSTEM\ControlSet002\services\Avgfwfd
2010-10-14 18:44:01,906 DEBUG Key SYSTEM\ControlSet002\services\Avgfwfd ForceRemove
2010-10-14 18:44:01,906 DEBUG Key SYSTEM\ControlSet002\services\Avgfwfd not found
2010-10-14 18:44:01,906 INFO Processing registry SYSTEM\ControlSet002\services\AVG Security Toolbar Service
2010-10-14 18:44:01,906 DEBUG Key SYSTEM\ControlSet002\services\AVG Security Toolbar Service ForceRemove
2010-10-14 18:44:01,906 DEBUG Key SYSTEM\ControlSet002\services\AVG Security Toolbar Service not found
2010-10-14 18:44:01,906 INFO Processing registry SYSTEM\ControlSet002\services\Avgfws
2010-10-14 18:44:01,921 DEBUG Key SYSTEM\ControlSet002\services\Avgfws ForceRemove
2010-10-14 18:44:01,921 DEBUG Key SYSTEM\ControlSet002\services\Avgfws not found
2010-10-14 18:44:01,921 INFO Processing registry SYSTEM\ControlSet002\services\AVGIDSAgent
2010-10-14 18:44:01,921 DEBUG Key SYSTEM\ControlSet002\services\AVGIDSAgent ForceRemove
2010-10-14 18:44:01,921 DEBUG Key SYSTEM\ControlSet002\services\AVGIDSAgent not found
2010-10-14 18:44:01,921 INFO Processing registry SYSTEM\ControlSet002\services\AVGIDSDriver
2010-10-14 18:44:01,921 DEBUG Key SYSTEM\ControlSet002\services\AVGIDSDriver ForceRemove
2010-10-14 18:44:01,921 DEBUG Key SYSTEM\ControlSet002\services\AVGIDSDriver not found
2010-10-14 18:44:01,921 INFO Processing registry SYSTEM\ControlSet002\services\AVGIDSEH
2010-10-14 18:44:01,921 DEBUG Key SYSTEM\ControlSet002\services\AVGIDSEH ForceRemove
2010-10-14 18:44:01,921 DEBUG Key SYSTEM\ControlSet002\services\AVGIDSEH not found
2010-10-14 18:44:01,921 INFO Processing registry SYSTEM\ControlSet002\services\AVGIDSFilter
2010-10-14 18:44:01,937 DEBUG Key SYSTEM\ControlSet002\services\AVGIDSFilter ForceRemove
2010-10-14 18:44:01,937 DEBUG Key SYSTEM\ControlSet002\services\AVGIDSFilter not found
2010-10-14 18:44:01,937 INFO Processing registry SYSTEM\ControlSet002\services\avgldx64
2010-10-14 18:44:01,937 DEBUG Key SYSTEM\ControlSet002\services\avgldx64 ForceRemove
2010-10-14 18:44:01,937 DEBUG Key SYSTEM\ControlSet002\services\avgldx64 not found
2010-10-14 18:44:01,937 INFO Processing registry SYSTEM\ControlSet002\services\avgldx86
2010-10-14 18:44:01,937 DEBUG Key SYSTEM\ControlSet002\services\avgldx86 ForceRemove
2010-10-14 18:44:01,937 DEBUG Key SYSTEM\ControlSet002\services\avgldx86 not found
2010-10-14 18:44:01,937 INFO Processing registry SYSTEM\ControlSet002\services\avgmfx64
2010-10-14 18:44:01,937 DEBUG Key SYSTEM\ControlSet002\services\avgmfx64 ForceRemove
2010-10-14 18:44:01,937 DEBUG Key SYSTEM\ControlSet002\services\avgmfx64 not found
2010-10-14 18:44:01,937 INFO Processing registry SYSTEM\ControlSet002\services\avgmfx86
2010-10-14 18:44:01,953 DEBUG Key SYSTEM\ControlSet002\services\avgmfx86 ForceRemove
2010-10-14 18:44:01,953 DEBUG Key SYSTEM\ControlSet002\services\avgmfx86 not found
2010-10-14 18:44:01,953 INFO Processing registry SYSTEM\ControlSet002\services\avgrkx64
2010-10-14 18:44:01,953 DEBUG Key SYSTEM\ControlSet002\services\avgrkx64 ForceRemove
2010-10-14 18:44:01,953 DEBUG Key SYSTEM\ControlSet002\services\avgrkx64 not found
2010-10-14 18:44:01,953 INFO Processing registry SYSTEM\ControlSet002\services\avgrkx86
2010-10-14 18:44:01,953 DEBUG Key SYSTEM\ControlSet002\services\avgrkx86 ForceRemove
2010-10-14 18:44:01,953 DEBUG Key SYSTEM\ControlSet002\services\avgrkx86 not found
2010-10-14 18:44:01,953 INFO Processing registry SYSTEM\ControlSet002\services\avgtdia
2010-10-14 18:44:01,953 DEBUG Key SYSTEM\ControlSet002\services\avgtdia ForceRemove
2010-10-14 18:44:01,953 DEBUG Key SYSTEM\ControlSet002\services\avgtdia not found
2010-10-14 18:44:01,953 INFO Processing registry SYSTEM\ControlSet002\services\avgtdix
2010-10-14 18:44:01,968 DEBUG Key SYSTEM\ControlSet002\services\avgtdix ForceRemove
2010-10-14 18:44:01,968 DEBUG Key SYSTEM\ControlSet002\services\avgtdix not found
2010-10-14 18:44:01,968 INFO Processing registry SYSTEM\ControlSet002\services\avgwd
2010-10-14 18:44:01,968 DEBUG Key SYSTEM\ControlSet002\services\avgwd ForceRemove
2010-10-14 18:44:01,968 DEBUG Key SYSTEM\ControlSet002\services\avgwd not found
2010-10-14 18:44:01,968 INFO Processing registry SYSTEM\CurrentControlSet\Enum\Root\LEGACY_AVGFWS
2010-10-14 18:44:01,968 DEBUG Key SYSTEM\CurrentControlSet\Enum\Root\LEGACY_AVGFWS ForceRemove
2010-10-14 18:44:01,968 DEBUG Key SYSTEM\CurrentControlSet\Enum\Root\LEGACY_AVGFWS not found
2010-10-14 18:44:01,968 INFO Processing registry SYSTEM\CurrentControlSet\Enum\Root\LEGACY_AVGIDSAGENT
2010-10-14 18:44:01,968 DEBUG Key SYSTEM\CurrentControlSet\Enum\Root\LEGACY_AVGIDSAGENT ForceRemove
2010-10-14 18:44:01,968 DEBUG Key SYSTEM\CurrentControlSet\Enum\Root\LEGACY_AVGIDSAGENT not found
2010-10-14 18:44:01,968 INFO Processing registry SYSTEM\CurrentControlSet\Enum\Root\LEGACY_AVGIDSDRIVER
2010-10-14 18:44:01,984 DEBUG Key SYSTEM\CurrentControlSet\Enum\Root\LEGACY_AVGIDSDRIVER ForceRemove
2010-10-14 18:44:01,984 DEBUG Key SYSTEM\CurrentControlSet\Enum\Root\LEGACY_AVGIDSDRIVER not found
2010-10-14 18:44:01,984 INFO Processing registry SYSTEM\CurrentControlSet\Enum\Root\LEGACY_AVGIDSEH
2010-10-14 18:44:01,984 DEBUG Key SYSTEM\CurrentControlSet\Enum\Root\LEGACY_AVGIDSEH ForceRemove
2010-10-14 18:44:01,984 DEBUG Key SYSTEM\CurrentControlSet\Enum\Root\LEGACY_AVGIDSEH not found
2010-10-14 18:44:01,984 INFO Processing registry SYSTEM\CurrentControlSet\Enum\Root\LEGACY_AVGIDSFILTER
2010-10-14 18:44:01,984 DEBUG Key SYSTEM\CurrentControlSet\Enum\Root\LEGACY_AVGIDSFILTER ForceRemove
2010-10-14 18:44:01,984 DEBUG Key SYSTEM\CurrentControlSet\Enum\Root\LEGACY_AVGIDSFILTER not found
2010-10-14 18:44:01,984 INFO Processing registry SYSTEM\CurrentControlSet\Enum\Root\LEGACY_AVGIDSSHIM
2010-10-14 18:44:01,984 DEBUG Key SYSTEM\CurrentControlSet\Enum\Root\LEGACY_AVGIDSSHIM ForceRemove
2010-10-14 18:44:01,984 DEBUG Key SYSTEM\CurrentControlSet\Enum\Root\LEGACY_AVGIDSSHIM not found
2010-10-14 18:44:01,984 INFO Processing registry SYSTEM\CurrentControlSet\Enum\Root\LEGACY_AVGLDX86
2010-10-14 18:44:02,000 DEBUG Key SYSTEM\CurrentControlSet\Enum\Root\LEGACY_AVGLDX86 ForceRemove
2010-10-14 18:44:02,000 WARN Deleting key SYSTEM\CurrentControlSet\Enum\Root\LEGACY_AVGLDX86 failed (error e0010058)
2010-10-14 18:44:02,000 INFO Processing registry SYSTEM\CurrentControlSet\Enum\Root\LEGACY_AVGMFX86
2010-10-14 18:44:02,000 DEBUG Key SYSTEM\CurrentControlSet\Enum\Root\LEGACY_AVGMFX86 ForceRemove
2010-10-14 18:44:02,000 WARN Deleting key SYSTEM\CurrentControlSet\Enum\Root\LEGACY_AVGMFX86 failed (error e0010058)
2010-10-14 18:44:02,000 INFO Processing registry SYSTEM\CurrentControlSet\Enum\Root\LEGACY_AVGRKX86
2010-10-14 18:44:02,015 DEBUG Key SYSTEM\CurrentControlSet\Enum\Root\LEGACY_AVGRKX86 ForceRemove
2010-10-14 18:44:02,015 WARN Deleting key SYSTEM\CurrentControlSet\Enum\Root\LEGACY_AVGRKX86 failed (error e0010058)
2010-10-14 18:44:02,015 INFO Processing registry SYSTEM\CurrentControlSet\Enum\Root\LEGACY_AVGLDX64
2010-10-14 18:44:02,015 DEBUG Key SYSTEM\CurrentControlSet\Enum\Root\LEGACY_AVGLDX64 ForceRemove
2010-10-14 18:44:02,015 DEBUG Key SYSTEM\CurrentControlSet\Enum\Root\LEGACY_AVGLDX64 not found
2010-10-14 18:44:02,015 INFO Processing registry SYSTEM\CurrentControlSet\Enum\Root\LEGACY_AVGMFX64
2010-10-14 18:44:02,015 DEBUG Key SYSTEM\CurrentControlSet\Enum\Root\LEGACY_AVGMFX64 ForceRemove
2010-10-14 18:44:02,015 DEBUG Key SYSTEM\CurrentControlSet\Enum\Root\LEGACY_AVGMFX64 not found
2010-10-14 18:44:02,015 INFO Processing registry SYSTEM\CurrentControlSet\Enum\Root\LEGACY_AVGRKX64
2010-10-14 18:44:02,031 DEBUG Key SYSTEM\CurrentControlSet\Enum\Root\LEGACY_AVGRKX64 ForceRemove
2010-10-14 18:44:02,031 DEBUG Key SYSTEM\CurrentControlSet\Enum\Root\LEGACY_AVGRKX64 not found
2010-10-14 18:44:02,031 INFO Processing registry SYSTEM\CurrentControlSet\Enum\Root\LEGACY_AVGTDIX
2010-10-14 18:44:02,031 DEBUG Key SYSTEM\CurrentControlSet\Enum\Root\LEGACY_AVGTDIX ForceRemove
2010-10-14 18:44:02,031 WARN Deleting key SYSTEM\CurrentControlSet\Enum\Root\LEGACY_AVGTDIX failed (error e0010058)
2010-10-14 18:44:02,031 INFO Processing registry SYSTEM\CurrentControlSet\Enum\Root\LEGACY_AVGTDIA
2010-10-14 18:44:02,046 DEBUG Key SYSTEM\CurrentControlSet\Enum\Root\LEGACY_AVGTDIA ForceRemove
2010-10-14 18:44:02,046 DEBUG Key SYSTEM\CurrentControlSet\Enum\Root\LEGACY_AVGTDIA not found
2010-10-14 18:44:02,046 INFO Processing registry SYSTEM\CurrentControlSet\Enum\Root\LEGACY_AVGWD
2010-10-14 18:44:02,046 DEBUG Key SYSTEM\CurrentControlSet\Enum\Root\LEGACY_AVGWD ForceRemove
2010-10-14 18:44:02,046 DEBUG Key SYSTEM\CurrentControlSet\Enum\Root\LEGACY_AVGWD not found
2010-10-14 18:44:02,046 INFO Processing registry SYSTEM\ControlSet001\Enum\Root\LEGACY_AVGFWS
2010-10-14 18:44:02,046 DEBUG Key SYSTEM\ControlSet001\Enum\Root\LEGACY_AVGFWS ForceRemove
2010-10-14 18:44:02,046 DEBUG Key SYSTEM\ControlSet001\Enum\Root\LEGACY_AVGFWS not found
2010-10-14 18:44:02,046 INFO Processing registry SYSTEM\ControlSet001\Enum\Root\LEGACY_AVGIDSAGENT
2010-10-14 18:44:02,046 DEBUG Key SYSTEM\ControlSet001\Enum\Root\LEGACY_AVGIDSAGENT ForceRemove
2010-10-14 18:44:02,046 DEBUG Key SYSTEM\ControlSet001\Enum\Root\LEGACY_AVGIDSAGENT not found
2010-10-14 18:44:02,046 INFO Processing registry SYSTEM\ControlSet001\Enum\Root\LEGACY_AVGIDSDRIVER
2010-10-14 18:44:02,062 DEBUG Key SYSTEM\ControlSet001\Enum\Root\LEGACY_AVGIDSDRIVER ForceRemove
2010-10-14 18:44:02,062 DEBUG Key SYSTEM\ControlSet001\Enum\Root\LEGACY_AVGIDSDRIVER not found
2010-10-14 18:44:02,062 INFO Processing registry SYSTEM\ControlSet001\Enum\Root\LEGACY_AVGIDSEH
2010-10-14 18:44:02,062 DEBUG Key SYSTEM\ControlSet001\Enum\Root\LEGACY_AVGIDSEH ForceRemove
2010-10-14 18:44:02,062 DEBUG Key SYSTEM\ControlSet001\Enum\Root\LEGACY_AVGIDSEH not found
2010-10-14 18:44:02,062 INFO Processing registry SYSTEM\ControlSet001\Enum\Root\LEGACY_AVGIDSFILTER
2010-10-14 18:44:02,062 DEBUG Key SYSTEM\ControlSet001\Enum\Root\LEGACY_AVGIDSFILTER ForceRemove
2010-10-14 18:44:02,062 DEBUG Key SYSTEM\ControlSet001\Enum\Root\LEGACY_AVGIDSFILTER not found
2010-10-14 18:44:02,062 INFO Processing registry SYSTEM\ControlSet001\Enum\Root\LEGACY_AVGIDSSHIM
2010-10-14 18:44:02,078 DEBUG Key SYSTEM\ControlSet001\Enum\Root\LEGACY_AVGIDSSHIM ForceRemove
2010-10-14 18:44:02,078 DEBUG Key SYSTEM\ControlSet001\Enum\Root\LEGACY_AVGIDSSHIM not found
2010-10-14 18:44:02,078 INFO Processing registry SYSTEM\ControlSet001\Enum\Root\LEGACY_AVGLDX86
2010-10-14 18:44:02,078 DEBUG Key SYSTEM\ControlSet001\Enum\Root\LEGACY_AVGLDX86 ForceRemove
2010-10-14 18:44:02,078 WARN Deleting key SYSTEM\ControlSet001\Enum\Root\LEGACY_AVGLDX86 failed (error e0010058)
2010-10-14 18:44:02,078 INFO Processing registry SYSTEM\ControlSet001\Enum\Root\LEGACY_AVGMFX86
2010-10-14 18:44:02,078 DEBUG Key SYSTEM\ControlSet001\Enum\Root\LEGACY_AVGMFX86 ForceRemove
2010-10-14 18:44:02,078 WARN Deleting key SYSTEM\ControlSet001\Enum\Root\LEGACY_AVGMFX86 failed (error e0010058)
2010-10-14 18:44:02,093 INFO Processing registry SYSTEM\ControlSet001\Enum\Root\LEGACY_AVGRKX86
2010-10-14 18:44:02,093 DEBUG Key SYSTEM\ControlSet001\Enum\Root\LEGACY_AVGRKX86 ForceRemove
2010-10-14 18:44:02,093 WARN Deleting key SYSTEM\ControlSet001\Enum\Root\LEGACY_AVGRKX86 failed (error e0010058)
2010-10-14 18:44:02,093 INFO Processing registry SYSTEM\ControlSet001\Enum\Root\LEGACY_AVGLDX64
2010-10-14 18:44:02,093 DEBUG Key SYSTEM\ControlSet001\Enum\Root\LEGACY_AVGLDX64 ForceRemove
2010-10-14 18:44:02,093 DEBUG Key SYSTEM\ControlSet001\Enum\Root\LEGACY_AVGLDX64 not found
2010-10-14 18:44:02,093 INFO Processing registry SYSTEM\ControlSet001\Enum\Root\LEGACY_AVGMFX64
2010-10-14 18:44:02,109 DEBUG Key SYSTEM\ControlSet001\Enum\Root\LEGACY_AVGMFX64 ForceRemove
2010-10-14 18:44:02,109 DEBUG Key SYSTEM\ControlSet001\Enum\Root\LEGACY_AVGMFX64 not found
2010-10-14 18:44:02,109 INFO Processing registry SYSTEM\ControlSet001\Enum\Root\LEGACY_AVGRKX64
2010-10-14 18:44:02,109 DEBUG Key SYSTEM\ControlSet001\Enum\Root\LEGACY_AVGRKX64 ForceRemove
2010-10-14 18:44:02,109 DEBUG Key SYSTEM\ControlSet001\Enum\Root\LEGACY_AVGRKX64 not found
2010-10-14 18:44:02,109 INFO Processing registry SYSTEM\ControlSet001\Enum\Root\LEGACY_AVGTDIX
2010-10-14 18:44:02,109 DEBUG Key SYSTEM\ControlSet001\Enum\Root\LEGACY_AVGTDIX ForceRemove
2010-10-14 18:44:02,109 WARN Deleting key SYSTEM\ControlSet001\Enum\Root\LEGACY_AVGTDIX failed (error e0010058)
2010-10-14 18:44:02,109 INFO Processing registry SYSTEM\ControlSet001\Enum\Root\LEGACY_AVGTDIA
2010-10-14 18:44:02,125 DEBUG Key SYSTEM\ControlSet001\Enum\Root\LEGACY_AVGTDIA ForceRemove
2010-10-14 18:44:02,125 DEBUG Key SYSTEM\ControlSet001\Enum\Root\LEGACY_AVGTDIA not found
2010-10-14 18:44:02,125 INFO Processing registry SYSTEM\ControlSet001\Enum\Root\LEGACY_AVGWD
2010-10-14 18:44:02,125 DEBUG Key SYSTEM\ControlSet001\Enum\Root\LEGACY_AVGWD ForceRemove
2010-10-14 18:44:02,125 DEBUG Key SYSTEM\ControlSet001\Enum\Root\LEGACY_AVGWD not found
2010-10-14 18:44:02,125 INFO Processing registry SYSTEM\ControlSet002\Enum\Root\LEGACY_AVGFWS
2010-10-14 18:44:02,125 DEBUG Key SYSTEM\ControlSet002\Enum\Root\LEGACY_AVGFWS ForceRemove
2010-10-14 18:44:02,125 DEBUG Key SYSTEM\ControlSet002\Enum\Root\LEGACY_AVGFWS not found
2010-10-14 18:44:02,125 INFO Processing registry SYSTEM\ControlSet002\Enum\Root\LEGACY_AVGIDSAGENT
2010-10-14 18:44:02,125 DEBUG Key SYSTEM\ControlSet002\Enum\Root\LEGACY_AVGIDSAGENT ForceRemove
2010-10-14 18:44:02,125 DEBUG Key SYSTEM\ControlSet002\Enum\Root\LEGACY_AVGIDSAGENT not found
2010-10-14 18:44:02,125 INFO Processing registry SYSTEM\ControlSet002\Enum\Root\LEGACY_AVGIDSDRIVER
2010-10-14 18:44:02,140 DEBUG Key SYSTEM\ControlSet002\Enum\Root\LEGACY_AVGIDSDRIVER ForceRemove
2010-10-14 18:44:02,140 DEBUG Key SYSTEM\ControlSet002\Enum\Root\LEGACY_AVGIDSDRIVER not found
2010-10-14 18:44:02,140 INFO Processing registry SYSTEM\ControlSet002\Enum\Root\LEGACY_AVGIDSEH
2010-10-14 18:44:02,140 DEBUG Key SYSTEM\ControlSet002\Enum\Root\LEGACY_AVGIDSEH ForceRemove
2010-10-14 18:44:02,140 DEBUG Key SYSTEM\ControlSet002\Enum\Root\LEGACY_AVGIDSEH not found
2010-10-14 18:44:02,140 INFO Processing registry SYSTEM\ControlSet002\Enum\Root\LEGACY_AVGIDSFILTER
2010-10-14 18:44:02,140 DEBUG Key SYSTEM\ControlSet002\Enum\Root\LEGACY_AVGIDSFILTER ForceRemove
2010-10-14 18:44:02,140 DEBUG Key SYSTEM\ControlSet002\Enum\Root\LEGACY_AVGIDSFILTER not found
2010-10-14 18:44:02,140 INFO Processing registry SYSTEM\ControlSet002\Enum\Root\LEGACY_AVGIDSSHIM
2010-10-14 18:44:02,140 DEBUG Key SYSTEM\ControlSet002\Enum\Root\LEGACY_AVGIDSSHIM ForceRemove
2010-10-14 18:44:02,140 DEBUG Key SYSTEM\ControlSet002\Enum\Root\LEGACY_AVGIDSSHIM not found
2010-10-14 18:44:02,140 INFO Processing registry SYSTEM\ControlSet002\Enum\Root\LEGACY_AVGLDX86
2010-10-14 18:44:02,156 DEBUG Key SYSTEM\ControlSet002\Enum\Root\LEGACY_AVGLDX86 ForceRemove
2010-10-14 18:44:02,156 WARN Deleting key SYSTEM\ControlSet002\Enum\Root\LEGACY_AVGLDX86 failed (error e0010058)
2010-10-14 18:44:02,156 INFO Processing registry SYSTEM\ControlSet002\Enum\Root\LEGACY_AVGMFX86
2010-10-14 18:44:02,156 DEBUG Key SYSTEM\ControlSet002\Enum\Root\LEGACY_AVGMFX86 ForceRemove
2010-10-14 18:44:02,156 WARN Deleting key SYSTEM\ControlSet002\Enum\Root\LEGACY_AVGMFX86 failed (error e0010058)
2010-10-14 18:44:02,156 INFO Processing registry SYSTEM\ControlSet002\Enum\Root\LEGACY_AVGRKX86
2010-10-14 18:44:02,171 DEBUG Key SYSTEM\ControlSet002\Enum\Root\LEGACY_AVGRKX86 ForceRemove
2010-10-14 18:44:02,171 WARN Deleting key SYSTEM\ControlSet002\Enum\Root\LEGACY_AVGRKX86 failed (error e0010058)
2010-10-14 18:44:02,171 INFO Processing registry SYSTEM\ControlSet002\Enum\Root\LEGACY_AVGLDX64
2010-10-14 18:44:02,171 DEBUG Key SYSTEM\ControlSet002\Enum\Root\LEGACY_AVGLDX64 ForceRemove
2010-10-14 18:44:02,171 DEBUG Key SYSTEM\ControlSet002\Enum\Root\LEGACY_AVGLDX64 not found
2010-10-14 18:44:02,171 INFO Processing registry SYSTEM\ControlSet002\Enum\Root\LEGACY_AVGMFX64
2010-10-14 18:44:02,171 DEBUG Key SYSTEM\ControlSet002\Enum\Root\LEGACY_AVGMFX64 ForceRemove
2010-10-14 18:44:02,171 DEBUG Key SYSTEM\ControlSet002\Enum\Root\LEGACY_AVGMFX64 not found
2010-10-14 18:44:02,171 INFO Processing registry SYSTEM\ControlSet002\Enum\Root\LEGACY_AVGRKX64
2010-10-14 18:44:02,187 DEBUG Key SYSTEM\ControlSet002\Enum\Root\LEGACY_AVGRKX64 ForceRemove
2010-10-14 18:44:02,187 DEBUG Key SYSTEM\ControlSet002\Enum\Root\LEGACY_AVGRKX64 not found
2010-10-14 18:44:02,187 INFO Processing registry SYSTEM\ControlSet002\Enum\Root\LEGACY_AVGTDIX
2010-10-14 18:44:02,187 DEBUG Key SYSTEM\ControlSet002\Enum\Root\LEGACY_AVGTDIX ForceRemove
2010-10-14 18:44:02,187 WARN Deleting key SYSTEM\ControlSet002\Enum\Root\LEGACY_AVGTDIX failed (error e0010058)
2010-10-14 18:44:02,187 INFO Processing registry SYSTEM\ControlSet002\Enum\Root\LEGACY_AVGTDIA
2010-10-14 18:44:02,203 DEBUG Key SYSTEM\ControlSet002\Enum\Root\LEGACY_AVGTDIA ForceRemove
2010-10-14 18:44:02,203 DEBUG Key SYSTEM\ControlSet002\Enum\Root\LEGACY_AVGTDIA not found
2010-10-14 18:44:02,203 INFO Processing registry SYSTEM\ControlSet002\Enum\Root\LEGACY_AVGWD
2010-10-14 18:44:02,203 DEBUG Key SYSTEM\ControlSet002\Enum\Root\LEGACY_AVGWD ForceRemove
2010-10-14 18:44:02,203 DEBUG Key SYSTEM\ControlSet002\Enum\Root\LEGACY_AVGWD not found
2010-10-14 18:44:02,203 INFO Processing registry SOFTWARE\AVG\Clients
2010-10-14 18:44:02,203 DEBUG Key SOFTWARE\AVG\Clients ForceRemove
2010-10-14 18:44:02,203 DEBUG Key SOFTWARE\AVG\Clients not found
2010-10-14 18:44:02,203 INFO Processing registry SOFTWARE\AVG\AVG8
2010-10-14 18:44:02,203 DEBUG Key SOFTWARE\AVG\AVG8 ForceRemove
2010-10-14 18:44:02,203 DEBUG Key SOFTWARE\AVG\AVG8 not found
2010-10-14 18:44:02,203 INFO Processing registry SOFTWARE\AVG\AVG9
2010-10-14 18:44:02,203 DEBUG Key SOFTWARE\AVG\AVG9 ForceRemove
2010-10-14 18:44:02,203 DEBUG Key SOFTWARE\AVG\AVG9 not found
2010-10-14 18:44:02,203 INFO Processing registry SOFTWARE\AVG\AVG10
2010-10-14 18:44:02,203 DEBUG Key SOFTWARE\AVG\AVG10 ForceRemove
2010-10-14 18:44:02,203 DEBUG Key SOFTWARE\AVG\AVG10 not found
2010-10-14 18:44:02,203 INFO Processing registry SOFTWARE\AVG\AVG IDS
2010-10-14 18:44:02,218 DEBUG Key SOFTWARE\AVG\AVG IDS ForceRemove
2010-10-14 18:44:02,218 DEBUG Key SOFTWARE\AVG\AVG IDS not found
2010-10-14 18:44:02,218 INFO Processing registry SOFTWARE\AVG\AVG IDS
2010-10-14 18:44:02,218 DEBUG Value SOFTWARE\AVG:DumpType Remove
2010-10-14 18:44:02,218 DEBUG Value SOFTWARE\AVG:DumpType not present - Key not found
2010-10-14 18:44:02,218 INFO Processing registry SOFTWARE\AVG\AvgAdmin10
2010-10-14 18:44:02,218 DEBUG Key SOFTWARE\AVG\AvgAdmin10 ForceRemove
2010-10-14 18:44:02,218 DEBUG Key SOFTWARE\AVG\AvgAdmin10 not found
2010-10-14 18:44:02,218 DEBUG Key SOFTWARE\AVG ForceRemove
2010-10-14 18:44:02,218 DEBUG Key SOFTWARE\AVG not found
2010-10-14 18:44:02,218 INFO Processing registry SOFTWARE\AVG Security Toolbar
2010-10-14 18:44:02,234 DEBUG Key SOFTWARE\AVG Security Toolbar ForceRemove
2010-10-14 18:44:02,234 DEBUG Key SOFTWARE\AVG Security Toolbar not found
2010-10-14 18:44:02,234 INFO Processing registry SOFTWARE\AVG Security Toolbar
2010-10-14 18:44:02,234 INFO Processing registry SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\AVG
2010-10-14 18:44:02,234 DEBUG Key SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\AVG ForceRemove
2010-10-14 18:44:02,234 DEBUG Key SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\AVG not found
2010-10-14 18:44:02,234 INFO Processing registry SOFTWARE\AVG\AVG8
2010-10-14 18:44:02,234 DEBUG Key SOFTWARE\AVG\AVG8 ForceRemove
2010-10-14 18:44:02,234 DEBUG Key SOFTWARE\AVG\AVG8 not found
2010-10-14 18:44:02,234 INFO Processing registry SOFTWARE\AVG\AVG9
2010-10-14 18:44:02,234 DEBUG Key SOFTWARE\AVG\AVG9 ForceRemove
2010-10-14 18:44:02,234 DEBUG Key SOFTWARE\AVG\AVG9 not found
2010-10-14 18:44:02,234 INFO Processing registry SOFTWARE\AVG\AVG10
2010-10-14 18:44:02,234 DEBUG Key SOFTWARE\AVG\AVG10 ForceRemove
2010-10-14 18:44:02,234 DEBUG Key SOFTWARE\AVG\AVG10 not found
2010-10-14 18:44:02,250 DEBUG Key SOFTWARE\AVG ForceRemove
2010-10-14 18:44:02,250 DEBUG Key SOFTWARE\AVG not found
2010-10-14 18:44:02,250 INFO Processing registry SOFTWARE\AVG
2010-10-14 18:44:02,250 INFO Processing registry SOFTWARE\AVG Security Toolbar
2010-10-14 18:44:02,250 DEBUG Key SOFTWARE\AVG Security Toolbar ForceRemove
2010-10-14 18:44:02,250 DEBUG Key SOFTWARE\AVG Security Toolbar not found
2010-10-14 18:44:02,250 INFO Processing registry SOFTWARE\Microsoft\Internet Explorer\URLSearchHooks
2010-10-14 18:44:02,250 DEBUG Value SOFTWARE\Microsoft\Internet Explorer\URLSearchHooks:{A3BC75A2-1F87-4686-AA43-5347D756017C} Remove
2010-10-14 18:44:02,250 INFO Value SOFTWARE\Microsoft\Internet Explorer\URLSearchHooks:{A3BC75A2-1F87-4686-AA43-5347D756017C} is not present
2010-10-14 18:44:02,250 INFO Processing registry SOFTWARE\Microsoft\Internet Explorer\SearchScopes\{CCC7A320-B3CA-4199-B1A6-9F516DD69829}
2010-10-14 18:44:02,265 DEBUG Key SOFTWARE\Microsoft\Internet Explorer\SearchScopes\{CCC7A320-B3CA-4199-B1A6-9F516DD69829} ForceRemove
2010-10-14 18:44:02,265 DEBUG Key SOFTWARE\Microsoft\Internet Explorer\SearchScopes\{CCC7A320-B3CA-4199-B1A6-9F516DD69829} not found
2010-10-14 18:44:02,265 INFO Processing registry SOFTWARE\Microsoft\Internet Explorer\Toolbar\WebBrowser
2010-10-14 18:44:02,265 DEBUG Value SOFTWARE\Microsoft\Internet Explorer\Toolbar\WebBrowser:{CCC7A320-B3CA-4199-B1A6-9F516DD69829} Remove
2010-10-14 18:44:02,265 INFO Value SOFTWARE\Microsoft\Internet Explorer\Toolbar\WebBrowser:{CCC7A320-B3CA-4199-B1A6-9F516DD69829} is not present
2010-10-14 18:44:02,265 INFO Processing registry SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{CCC7A320-B3CA-4199-B1A6-9F516DD69829}
2010-10-14 18:44:02,265 DEBUG Key SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{CCC7A320-B3CA-4199-B1A6-9F516DD69829} ForceRemove
2010-10-14 18:44:02,265 DEBUG Key SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{CCC7A320-B3CA-4199-B1A6-9F516DD69829} not found
2010-10-14 18:44:02,265 INFO Processing registry SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{A3BC75A2-1F87-4686-AA43-5347D756017C}
2010-10-14 18:44:02,281 DEBUG Key SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{A3BC75A2-1F87-4686-AA43-5347D756017C} ForceRemove
2010-10-14 18:44:02,281 DEBUG Key SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{A3BC75A2-1F87-4686-AA43-5347D756017C} not found
2010-10-14 18:44:02,281 INFO Processing registry SOFTWARE\AppDataLow\Avg
2010-10-14 18:44:02,281 DEBUG Key SOFTWARE\AppDataLow\Avg ForceRemove
2010-10-14 18:44:02,281 DEBUG Key SOFTWARE\AppDataLow\Avg not found
2010-10-14 18:44:02,281 INFO Processing registry SOFTWARE\AppDataLow\Software\AVG Security Toolbar
2010-10-14 18:44:02,281 DEBUG Key SOFTWARE\AppDataLow\Software\AVG Security Toolbar ForceRemove
2010-10-14 18:44:02,281 DEBUG Key SOFTWARE\AppDataLow\Software\AVG Security Toolbar not found
2010-10-14 18:44:02,281 INFO Processing registry .avgdxa
2010-10-14 18:44:02,281 DEBUG Key .avgdxa ForceRemove
2010-10-14 18:44:02,281 DEBUG Key .avgdxa not found
2010-10-14 18:44:02,281 INFO Processing registry aAvgAPI.AvgBro
2010-10-14 18:44:02,281 DEBUG Key aAvgAPI.AvgBro ForceRemove
2010-10-14 18:44:02,281 DEBUG Key aAvgAPI.AvgBro not found
2010-10-14 18:44:02,281 INFO Processing registry AVG.Office
2010-10-14 18:44:02,296 DEBUG Key AVG.Office ForceRemove
2010-10-14 18:44:02,296 DEBUG Key AVG.Office not found
2010-10-14 18:44:02,296 INFO Processing registry AVG.Office.8
2010-10-14 18:44:02,296 DEBUG Key AVG.Office.8 ForceRemove
2010-10-14 18:44:02,296 DEBUG Key AVG.Office.8 not found
2010-10-14 18:44:02,296 INFO Processing registry avgtoolbar.AVGTOOLBAR
2010-10-14 18:44:02,296 DEBUG Key avgtoolbar.AVGTOOLBAR ForceRemove
2010-10-14 18:44:02,296 DEBUG Key avgtoolbar.AVGTOOLBAR not found
2010-10-14 18:44:02,296 INFO Processing registry avgtoolbar.AVGTOOLBARMenu Button
2010-10-14 18:44:02,296 DEBUG Key avgtoolbar.AVGTOOLBARMenu Button ForceRemove
2010-10-14 18:44:02,296 DEBUG Key avgtoolbar.AVGTOOLBARMenu Button not found
2010-10-14 18:44:02,296 INFO Processing registry avgtoolbar.AVGTOOLBARToggle Button
2010-10-14 18:44:02,296 DEBUG Key avgtoolbar.AVGTOOLBARToggle Button ForceRemove
2010-10-14 18:44:02,296 DEBUG Key avgtoolbar.AVGTOOLBARToggle Button not found
2010-10-14 18:44:02,296 INFO Processing registry LinkScannerIE.NavFilter
2010-10-14 18:44:02,296 DEBUG Key LinkScannerIE.NavFilter ForceRemove
2010-10-14 18:44:02,296 DEBUG Key LinkScannerIE.NavFilter not found
2010-10-14 18:44:02,296 INFO Processing registry LinkScannerIE.NavFilter.1
2010-10-14 18:44:02,312 DEBUG Key LinkScannerIE.NavFilter.1 ForceRemove
2010-10-14 18:44:02,312 DEBUG Key LinkScannerIE.NavFilter.1 not found
2010-10-14 18:44:02,312 INFO Processing registry CLSID\{04373D9C-5ED8-44f2-BA00-7895D6A5A2DA}
2010-10-14 18:44:02,312 DEBUG Key CLSID\{04373D9C-5ED8-44f2-BA00-7895D6A5A2DA} ForceRemove
2010-10-14 18:44:02,312 DEBUG Key CLSID\{04373D9C-5ED8-44f2-BA00-7895D6A5A2DA} not found
2010-10-14 18:44:02,312 INFO Processing registry CLSID\{18B30EBF-6B58-425E-AC54-831C05D91B5A}
2010-10-14 18:44:02,312 DEBUG Key CLSID\{18B30EBF-6B58-425E-AC54-831C05D91B5A} ForceRemove
2010-10-14 18:44:02,312 DEBUG Key CLSID\{18B30EBF-6B58-425E-AC54-831C05D91B5A} not found
2010-10-14 18:44:02,312 INFO Processing registry CLSID\{3CA2F312-6F6E-4B53-A66E-4E65E497C8C0}
2010-10-14 18:44:02,312 DEBUG Key CLSID\{3CA2F312-6F6E-4B53-A66E-4E65E497C8C0} ForceRemove
2010-10-14 18:44:02,312 DEBUG Key CLSID\{3CA2F312-6F6E-4B53-A66E-4E65E497C8C0} not found
2010-10-14 18:44:02,312 INFO Processing registry CLSID\{9F97547E-4609-42C5-AE0C-81C61FFAEBC3}
2010-10-14 18:44:02,328 DEBUG Key CLSID\{9F97547E-4609-42C5-AE0C-81C61FFAEBC3} ForceRemove
2010-10-14 18:44:02,328 DEBUG Key CLSID\{9F97547E-4609-42C5-AE0C-81C61FFAEBC3} not found
2010-10-14 18:44:02,328 INFO Processing registry CLSID\{9F97547E-4609-42C5-AE0C-81C61FFAEBC3}
2010-10-14 18:44:02,328 INFO Processing registry CLSID\{A057A204-BACC-4D26-9990-79A187E2698E}
2010-10-14 18:44:02,328 DEBUG Key CLSID\{A057A204-BACC-4D26-9990-79A187E2698E} ForceRemove
2010-10-14 18:44:02,328 DEBUG Key CLSID\{A057A204-BACC-4D26-9990-79A187E2698E} not found
2010-10-14 18:44:02,328 INFO Processing registry CLSID\{A057A204-BACC-4D26-9990-79A187E2698F}
2010-10-14 18:44:02,328 DEBUG Key CLSID\{A057A204-BACC-4D26-9990-79A187E2698F} ForceRemove
2010-10-14 18:44:02,328 DEBUG Key CLSID\{A057A204-BACC-4D26-9990-79A187E2698F} not found
2010-10-14 18:44:02,328 INFO Processing registry CLSID\{A057A204-BACC-4D26-9990-79A187E26990}
2010-10-14 18:44:02,343 DEBUG Key CLSID\{A057A204-BACC-4D26-9990-79A187E26990} ForceRemove
2010-10-14 18:44:02,343 DEBUG Key CLSID\{A057A204-BACC-4D26-9990-79A187E26990} not found
2010-10-14 18:44:02,343 INFO Processing registry CLSID\{F274614C-63F8-47D5-A4D1-FBDDE494F8D1}
2010-10-14 18:44:02,343 DEBUG Key CLSID\{F274614C-63F8-47D5-A4D1-FBDDE494F8D1} ForceRemove
2010-10-14 18:44:02,343 DEBUG Key CLSID\{F274614C-63F8-47D5-A4D1-FBDDE494F8D1} not found
2010-10-14 18:44:02,343 INFO Processing registry CLSID\{9781B2D1-AF27-474F-A3A5-C0763FBDF3B7}
2010-10-14 18:44:02,343 DEBUG Key CLSID\{9781B2D1-AF27-474F-A3A5-C0763FBDF3B7} ForceRemove
2010-10-14 18:44:02,343 DEBUG Key CLSID\{9781B2D1-AF27-474F-A3A5-C0763FBDF3B7} not found
2010-10-14 18:44:02,343 INFO Processing registry CLSID\{A3BC75A2-1F87-4686-AA43-5347D756017C}
2010-10-14 18:44:02,343 DEBUG Key CLSID\{A3BC75A2-1F87-4686-AA43-5347D756017C} ForceRemove
2010-10-14 18:44:02,343 DEBUG Key CLSID\{A3BC75A2-1F87-4686-AA43-5347D756017C} not found
2010-10-14 18:44:02,343 INFO Processing registry CLSID\{CCC7A320-B3CA-4199-B1A6-9F516DD69829}
2010-10-14 18:44:02,359 DEBUG Key CLSID\{CCC7A320-B3CA-4199-B1A6-9F516DD69829} ForceRemove
2010-10-14 18:44:02,359 DEBUG Key CLSID\{CCC7A320-B3CA-4199-B1A6-9F516DD69829} not found
2010-10-14 18:44:02,359 INFO Processing registry Interface\{52261B0E-CA1A-4FA9-9805-4D01202DF09D}
2010-10-14 18:44:02,359 DEBUG Key Interface\{52261B0E-CA1A-4FA9-9805-4D01202DF09D} ForceRemove
2010-10-14 18:44:02,375 DEBUG Key Interface\{52261B0E-CA1A-4FA9-9805-4D01202DF09D} not found
2010-10-14 18:44:02,375 INFO Processing registry Interface\{8EA1F9F2-997A-4832-8E09-815E3D0C0A0C}
2010-10-14 18:44:02,375 DEBUG Key Interface\{8EA1F9F2-997A-4832-8E09-815E3D0C0A0C} ForceRemove
2010-10-14 18:44:02,390 DEBUG Key Interface\{8EA1F9F2-997A-4832-8E09-815E3D0C0A0C} not found
2010-10-14 18:44:02,390 INFO Processing registry Interface\{7F24AABF-C822-4C18-9432-21433208F4DC}
2010-10-14 18:44:02,390 DEBUG Key Interface\{7F24AABF-C822-4C18-9432-21433208F4DC} ForceRemove
2010-10-14 18:44:02,406 DEBUG Key Interface\{7F24AABF-C822-4C18-9432-21433208F4DC} not found
2010-10-14 18:44:02,406 INFO Processing registry TypeLib\{3E536428-8E1A-4A2C-8463-4A8F74763C30}
2010-10-14 18:44:02,406 DEBUG Key TypeLib\{3E536428-8E1A-4A2C-8463-4A8F74763C30} ForceRemove
2010-10-14 18:44:02,406 DEBUG Key TypeLib\{3E536428-8E1A-4A2C-8463-4A8F74763C30} not found
2010-10-14 18:44:02,406 INFO Processing registry TypeLib\{5DAB1D4C-D020-41CD-936F-D63FF662E9F7}
2010-10-14 18:44:02,406 DEBUG Key TypeLib\{5DAB1D4C-D020-41CD-936F-D63FF662E9F7} ForceRemove
2010-10-14 18:44:02,406 DEBUG Key TypeLib\{5DAB1D4C-D020-41CD-936F-D63FF662E9F7} not found
2010-10-14 18:44:02,406 INFO Processing registry TypeLib\{A0C8F0F1-DE25-4ADB-8F0B-508F6CA43DE9}
2010-10-14 18:44:02,406 DEBUG Key TypeLib\{A0C8F0F1-DE25-4ADB-8F0B-508F6CA43DE9} ForceRemove
2010-10-14 18:44:02,421 DEBUG Key TypeLib\{A0C8F0F1-DE25-4ADB-8F0B-508F6CA43DE9} not found
2010-10-14 18:44:02,421 INFO Processing registry TypeLib\{CCC7A320-B3CA-4199-B1A6-9F516DD69829}
2010-10-14 18:44:02,421 DEBUG Key TypeLib\{CCC7A320-B3CA-4199-B1A6-9F516DD69829} ForceRemove
2010-10-14 18:44:02,421 DEBUG Key TypeLib\{CCC7A320-B3CA-4199-B1A6-9F516DD69829} not found
2010-10-14 18:44:02,421 INFO Processing registry CLSID\{8B39AD4E-1AB3-4AE1-B533-706F1CACED83}
2010-10-14 18:44:02,421 DEBUG Key CLSID\{8B39AD4E-1AB3-4AE1-B533-706F1CACED83} ForceRemove
2010-10-14 18:44:02,421 DEBUG Key CLSID\{8B39AD4E-1AB3-4AE1-B533-706F1CACED83} not found
2010-10-14 18:44:02,421 INFO Processing registry CLSID\{6E801D47-45B7-4D10-8268-DBBD5C233F82}
2010-10-14 18:44:02,421 DEBUG Key CLSID\{6E801D47-45B7-4D10-8268-DBBD5C233F82} ForceRemove
2010-10-14 18:44:02,421 DEBUG Key CLSID\{6E801D47-45B7-4D10-8268-DBBD5C233F82} not found
2010-10-14 18:44:02,421 INFO Processing registry CLSID\{DC182551-99C7-4e28-A8F3-8DCFC4745C4C}
2010-10-14 18:44:02,437 DEBUG Key CLSID\{DC182551-99C7-4e28-A8F3-8DCFC4745C4C} ForceRemove
2010-10-14 18:44:02,437 DEBUG Key CLSID\{DC182551-99C7-4e28-A8F3-8DCFC4745C4C} not found
2010-10-14 18:44:02,437 DEBUG Removing Session Manager values
2010-10-14 18:44:02,437 DEBUG Registry remover failed for some registry item(s)
2010-10-14 18:44:02,437 INFO ***** Files and folders *****
2010-10-14 18:44:02,437 DEBUG Missing ParentDir path for fileItem number 0
2010-10-14 18:44:02,437 DEBUG Missing ParentDir path for fileItem number 1
2010-10-14 18:44:02,437 DEBUG Missing ParentDir path for fileItem number 2
2010-10-14 18:44:02,437 DEBUG Missing ParentDir path for fileItem number 3
2010-10-14 18:44:02,437 DEBUG Missing ParentDir path for fileItem number 4
2010-10-14 18:44:02,437 DEBUG Missing ParentDir path for fileItem number 5
2010-10-14 18:44:02,437 DEBUG Missing ParentDir path for fileItem number 6
2010-10-14 18:44:02,437 DEBUG Missing ParentDir path for fileItem number 7
2010-10-14 18:44:02,437 DEBUG Missing ParentDir path for fileItem number 8
2010-10-14 18:44:02,437 DEBUG Missing ParentDir path for fileItem number 9
2010-10-14 18:44:02,437 DEBUG Missing ParentDir path for fileItem number 10
2010-10-14 18:44:02,437 DEBUG Missing ParentDir path for fileItem number 11
2010-10-14 18:44:02,437 DEBUG Missing ParentDir path for fileItem number 12
2010-10-14 18:44:02,437 DEBUG Missing ParentDir path for fileItem number 13
2010-10-14 18:44:02,437 DEBUG Missing ParentDir path for fileItem number 14
2010-10-14 18:44:02,437 DEBUG Missing ParentDir path for fileItem number 15
2010-10-14 18:44:02,437 DEBUG Missing ParentDir path for fileItem number 16
2010-10-14 18:44:02,437 DEBUG Processing item 'C:\Documents and Settings\user\Application Data\AVGTOOLBAR'
2010-10-14 18:44:02,437 INFO Directory 'C:\Documents and Settings\user\Application Data\AVGTOOLBAR' not found
2010-10-14 18:44:02,437 DEBUG Processing item 'C:\WINDOWS\System32\Drivers'
2010-10-14 18:44:02,437 DEBUG Processing item 'C:\Documents and Settings\All Users\Start Menu\Programs\avg 8.0'
2010-10-14 18:44:02,437 INFO Directory 'C:\Documents and Settings\All Users\Start Menu\Programs\avg 8.0' not found
2010-10-14 18:44:02,437 DEBUG Processing item 'C:\Documents and Settings\All Users\Start Menu\Programs\avg free 8.0'
2010-10-14 18:44:02,437 INFO Directory 'C:\Documents and Settings\All Users\Start Menu\Programs\avg free 8.0' not found
2010-10-14 18:44:02,453 DEBUG Processing item 'C:\Documents and Settings\All Users\Start Menu\Programs\avg 8.5'
2010-10-14 18:44:02,453 INFO Directory 'C:\Documents and Settings\All Users\Start Menu\Programs\avg 8.5' not found
2010-10-14 18:44:02,453 DEBUG Processing item 'C:\Documents and Settings\All Users\Start Menu\Programs\avg free 8.5'
2010-10-14 18:44:02,453 INFO Directory 'C:\Documents and Settings\All Users\Start Menu\Programs\avg free 8.5' not found
2010-10-14 18:44:02,453 DEBUG Processing item 'C:\Documents and Settings\All Users\Desktop\avg 8.0.lnk'
2010-10-14 18:44:02,453 INFO File 'C:\Documents and Settings\All Users\Desktop\avg 8.0.lnk' not found
2010-10-14 18:44:02,453 DEBUG Processing item 'C:\Documents and Settings\All Users\Desktop\avg free 8.0.lnk'
2010-10-14 18:44:02,453 INFO File 'C:\Documents and Settings\All Users\Desktop\avg free 8.0.lnk' not found
2010-10-14 18:44:02,468 DEBUG Processing item 'C:\Documents and Settings\All Users\Desktop\avg 8.5.lnk'
2010-10-14 18:44:02,468 INFO File 'C:\Documents and Settings\All Users\Desktop\avg 8.5.lnk' not found
2010-10-14 18:44:02,468 DEBUG Processing item 'C:\Documents and Settings\All Users\Desktop\avg free 8.5.lnk'
2010-10-14 18:44:02,468 INFO File 'C:\Documents and Settings\All Users\Desktop\avg free 8.5.lnk' not found
2010-10-14 18:44:02,468 DEBUG Missing ParentDir path for fileItem number 27
2010-10-14 18:44:02,468 DEBUG Missing ParentDir path for fileItem number 28
2010-10-14 18:44:02,468 DEBUG Missing ParentDir path for fileItem number 29
2010-10-14 18:44:02,468 DEBUG Missing ParentDir path for fileItem number 30
2010-10-14 18:44:02,468 DEBUG Missing ParentDir path for fileItem number 31
2010-10-14 18:44:02,468 DEBUG Missing ParentDir path for fileItem number 32
2010-10-14 18:44:02,468 DEBUG Missing ParentDir path for fileItem number 33
2010-10-14 18:44:02,468 DEBUG Missing ParentDir path for fileItem number 34
2010-10-14 18:44:02,468 DEBUG Missing ParentDir path for fileItem number 35
2010-10-14 18:44:02,468 DEBUG Missing ParentDir path for fileItem number 36
2010-10-14 18:44:02,468 DEBUG Missing ParentDir path for fileItem number 37
2010-10-14 18:44:02,468 DEBUG Missing ParentDir path for fileItem number 38
2010-10-14 18:44:02,468 DEBUG Missing ParentDir path for fileItem number 39
2010-10-14 18:44:02,468 DEBUG Missing ParentDir path for fileItem number 40
2010-10-14 18:44:02,468 DEBUG Missing ParentDir path for fileItem number 41
2010-10-14 18:44:02,468 DEBUG Missing ParentDir path for fileItem number 42
2010-10-14 18:44:02,468 DEBUG Missing ParentDir path for fileItem number 43
2010-10-14 18:44:02,468 DEBUG Missing ParentDir path for fileItem number 44
2010-10-14 18:44:02,468 DEBUG Missing ParentDir path for fileItem number 45
2010-10-14 18:44:02,468 DEBUG Missing ParentDir path for fileItem number 46
2010-10-14 18:44:02,468 DEBUG Missing ParentDir path for fileItem number 47
2010-10-14 18:44:02,468 DEBUG Missing ParentDir path for fileItem number 48
2010-10-14 18:44:02,468 DEBUG Processing item 'C:\Documents and Settings\All Users\Application Data\AVG Security Toolbar\Languages'
2010-10-14 18:44:02,468 INFO Directory 'C:\Documents and Settings\All Users\Application Data\AVG Security Toolbar\Languages' not found
2010-10-14 18:44:02,468 DEBUG Processing item 'C:\Documents and Settings\All Users\Application Data\AVG Security Toolbar\Update'
2010-10-14 18:44:02,468 INFO Directory 'C:\Documents and Settings\All Users\Application Data\AVG Security Toolbar\Update' not found
2010-10-14 18:44:02,484 DEBUG Processing item 'C:\Documents and Settings\All Users\Application Data\AVG Security Toolbar'
2010-10-14 18:44:02,484 INFO Directory 'C:\Documents and Settings\All Users\Application Data\AVG Security Toolbar' not found
2010-10-14 18:44:02,484 DEBUG Processing item 'C:\WINDOWS\System32\Drivers'
2010-10-14 18:44:02,484 DEBUG Processing item 'C:\Documents and Settings\All Users\Desktop\avg 9.0.lnk'
2010-10-14 18:44:02,484 INFO File 'C:\Documents and Settings\All Users\Desktop\avg 9.0.lnk' not found
2010-10-14 18:44:02,484 DEBUG Processing item 'C:\Documents and Settings\All Users\Desktop\avg free 9.0.lnk'
2010-10-14 18:44:02,484 INFO File 'C:\Documents and Settings\All Users\Desktop\avg free 9.0.lnk' not found
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 55
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 56
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 57
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 58
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 59
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 60
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 61
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 62
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 63
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 64
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 65
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 66
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 67
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 68
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 69
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 70
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 71
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 72
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 73
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 74
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 75
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 76
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 77
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 78
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 79
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 80
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 81
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 82
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 83
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 84
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 85
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 86
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 87
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 88
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 89
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 90
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 91
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 92
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 93
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 94
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 95
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 96
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 97
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 98
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 99
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 100
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 101
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 102
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 103
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 104
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 105
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 106
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 107
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 108
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 109
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 110
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 111
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 112
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 113
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 114
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 115
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 116
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 117
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 118
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 119
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 120
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 121
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 122
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 123
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 124
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 125
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 126
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 127
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 128
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 129
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 130
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 131
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 132
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 133
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 134
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 135
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 136
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 137
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 138
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 139
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 140
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 141
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 142
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 143
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 144
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 145
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 146
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 147
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 148
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 149
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 150
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 151
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 152
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 153
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 154
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 155
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 156
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 157
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 158
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 159
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 160
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 161
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 162
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 163
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 164
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 165
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 166
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 167
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 168
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 169
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 170
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 171
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 172
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 173
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 174
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 175
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 176
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 177
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 178
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 179
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 180
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 181
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 182
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 183
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 184
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 185
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 186
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 187
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 188
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 189
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 190
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 191
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 192
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 193
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 194
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 195
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 196
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 197
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 198
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 199
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 200
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 201
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 202
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 203
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 204
2010-10-14 18:44:02,484 DEBUG Missing ParentDir path for fileItem number 205
2010-10-14 18:44:02,500 DEBUG Processing item 'C:\WINDOWS\System32\Drivers'
2010-10-14 18:44:02,500 DEBUG Processing item 'C:\WINDOWS\System32\Drivers\AVG'
2010-10-14 18:44:02,500 INFO Directory 'C:\WINDOWS\System32\Drivers\AVG' not found
2010-10-14 18:44:02,500 DEBUG Processing item 'C:\WINDOWS\System32'
2010-10-14 18:44:02,500 DEBUG Processing item 'C:\Program Files\Windows Sidebar\Shared Gadgets\AVG.Gadget'
2010-10-14 18:44:02,500 INFO Directory 'C:\Program Files\Windows Sidebar\Shared Gadgets\AVG.Gadget' not found
2010-10-14 18:44:02,500 DEBUG Missing ParentDir path for fileItem number 215
2010-10-14 18:44:02,500 DEBUG Processing item 'C:\Documents and Settings\All Users\Application Data\AVG10\SetupCoreBackup'
2010-10-14 18:44:02,500 INFO Directory 'C:\Documents and Settings\All Users\Application Data\AVG10\SetupCoreBackup' not found
2010-10-14 18:44:02,500 DEBUG Processing item 'C:\Documents and Settings\All Users\Application Data\AVG10\SetupBackup'
2010-10-14 18:44:02,500 INFO Directory 'C:\Documents and Settings\All Users\Application Data\AVG10\SetupBackup' not found
2010-10-14 18:44:02,515 DEBUG Processing item 'C:\Documents and Settings\All Users\Application Data\AVG10\Chjw'
2010-10-14 18:44:02,515 INFO Directory 'C:\Documents and Settings\All Users\Application Data\AVG10\Chjw' not found
2010-10-14 18:44:02,515 DEBUG Processing item 'C:\Documents and Settings\All Users\Application Data\AVG10\Antispam'
2010-10-14 18:44:02,515 INFO Directory 'C:\Documents and Settings\All Users\Application Data\AVG10\Antispam' not found
2010-10-14 18:44:02,515 DEBUG Processing item 'C:\Documents and Settings\All Users\Application Data\AVG10'
2010-10-14 18:44:02,515 INFO Directory 'C:\Documents and Settings\All Users\Application Data\AVG10' not found
2010-10-14 18:44:02,515 DEBUG Processing item 'C:\Documents and Settings\All Users\Start Menu\Programs\AVG 2011'
2010-10-14 18:44:02,515 INFO Directory 'C:\Documents and Settings\All Users\Start Menu\Programs\AVG 2011' not found
2010-10-14 18:44:02,531 DEBUG Processing item 'C:\Documents and Settings\All Users\Start Menu\Programs\AVG FREE 2011'
2010-10-14 18:44:02,531 INFO Directory 'C:\Documents and Settings\All Users\Start Menu\Programs\AVG FREE 2011' not found
2010-10-14 18:44:02,531 DEBUG Processing item 'C:\Documents and Settings\All Users\Desktop\AVG 2011.lnk'
2010-10-14 18:44:02,531 INFO File 'C:\Documents and Settings\All Users\Desktop\AVG 2011.lnk' not found
2010-10-14 18:44:02,531 DEBUG Processing item 'C:\Documents and Settings\All Users\Desktop\AVG FREE 2011.lnk'
2010-10-14 18:44:02,531 INFO File 'C:\Documents and Settings\All Users\Desktop\AVG FREE 2011.lnk' not found
2010-10-14 18:44:02,531 DEBUG Processing item 'C:\WINDOWS\SysWOW64\Drivers\AVG'
2010-10-14 18:44:02,531 INFO Directory 'C:\WINDOWS\SysWOW64\Drivers\AVG' not found
2010-10-14 18:44:02,546 DEBUG Missing ParentDir path for fileItem number 226
Не знам точно какво си правил, но според мен просто си повредил инсталацията/деинсталацията на AVG. Като идея ми хрумва, да пробваш да инсталираш и след това да деинсталираш програмата по културен начин (през Control Panel).
:bravo: Браво,получи се.Благодаря много за помоща.Сега се надявам да ми препоръчате някоя що годе добра анти-вирусна. :peace: :bravo:
  • 2 years later...
Здравейте имам проблем с AVG Инсталираха ми Windows 8 преди 2 дни .И когато си включа компа ми пише.The program cant start because MSVCR100.dll is missing from your computer.TRY reinstalling the program to fix this problem.Много ще съм благодарен ако някой успее да ми помогне.
Имате ли инсталиран (ако е x64 битов Windows - инсталирайте и двата файла - vcredist_x64.exe и vcredist_x86.exe)
http://www.microsoft.com/en-us/download/details.aspx?id=26999
Поздрави!
Изтеглете Autoruns
  • Запазете файла на Вашия десктоп и го разархивирайте в директория по Ваше желание.
  • Стартирайте програмата.
  • Меню Options -> Filter Options... -> поставете отметка пред Hide Microsoft Entries.
  • Запазете промените.
  • Mеню File -> Refresh.
  • Mеню File -> Save....
Запазете файла, архивирайте го чрез софтуер по желание и го прикачете към следващия Ви коментар.
Моля, прикачете запазения от Вас файл към следващия Ви коментар. Никой не е споменал, че след сканиране с програмата, проблемът ще изчезне.
Ако си мислите, че тук сме магове и решаваме проблемите на потребителите без никаква информация, то жестоко се лъжете. Как искате да получите помощ за дадения проблем, след като не следвате стъпките, които сме Ви посъветвали да направите? Щом толкова желаете някой друг да Ви помогне, нека да е така. Аз приключвам участието си по този проблем.
